Question about Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Upper Thread Snapping
My Brother has worked fine up till today. Took it out to work on some crushed velvet (zig-zagging) and the upper thread kept snapping in the tension wheel and the lower thread kept bunching up. Now it won't sew properly at all, straight stitch or zig-zag. The thread continues to keep on snapping, getting caught really tight in the tension wheel (although I had checked before I started sewing that it was running through fine) and the bottom stitch keeps on looping and bunching up. Have looked through my manual, but no help offered there. Please help!
  • Ashley_cf21 Feb 14, 2009
    I started a project and i have the same problem with this machine. the thread either looks ok on the top and verryy loose on the bottom and when i pulled on the bottom stich to chech the strengh (tension) it pulled out all the stitches. and it also tends to bread tread on the top way to much and way to easy. what do i do? i have had this problem almost constantly and i cant afford a new machine. i have oiled and cleaded and even bought the most exxpesive tread that i could find. HELP PLEASE
  • Anonymous Mar 19, 2014
    I have a singer 417 zig zag and stretch model, what thread tension should I use for the stretch stitch - sewing lingere
I had the same problem and it was so frustrating! It was happening to me because I wasn't using the right size needle. Go up a couple of needle sizes and see if that helps.
Posted on Mar 09, 2009
My brother LS-2125 will not do zigzag stitch needle moves from side to side but only does occasionally zigzag
If you are saying the needle zig-zags but the upper thread is not catching the bobbin thread every stitch, then it could be a timing issue.
Jul 08, 2016 | Brother Sewing Machines
Why does upper thread break when I try to sew zig zag stitch?
Your tension sounds too tight, try lowering it on the upper thread. Or you may be using a cheap thread which frays easily and frays in the needle. Try using a longer zigzag to see if that works. Is straight stitch smooth?
Nov 02, 2015 | Brother Ls-2125i 10-stitch Portable Free...
How to sew Shell Tuck Stitch.
I can't find an image clear enough to actually see the stitch selection on the front of this machine.
Does it have a stitch that looks like three or 4 straight stitches, then one zig zag, then more straight stitches? This is the stitch you want to select to do a shell tuck.
Then hold your fabric with right side up and turn edge under about 8mm and seam along the edge using this stich so that the zig zag stitch goes over the folded edge each time to the right. This should pull in the folded edge a little giving a scalloped edge.
Just do a couple of trials to work out the best position for the folded edge on the needle plate to get the effect right, probably just the edge of the normal straight stitch but it varies for each machine. If your machine does this stitch with a variable adjustment on the width of the zig zag part, then you could finesse it with this too.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
Upper thread keeps breaking
the tension is too tight give it a little slack on the top.good luck.
Feb 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Appearence of loop and no zigzag stich on ls-2125i brother
The loopy stitching is usually do to threading the machine with the presser foot down.
Raise the presser foot and re-thread or pull about 8" of thread through the needle and see if the loopy stitches go away.
This may also be the issue with the zig-zag stitch.
When the machine is threaded with the presser foot down, the tension is closed and the thread cannot enter as it should for the tension to control the flow of thread to the needle. The thread then feeds too fast and the stitching is distorted.
Feb 17, 2010 | Brother LS-2125 Mechanical Sewing Machine
Thread keeps snapping - Brother JS 23
Try adjusting your tension. I had this same problem and then I adjusted the tension of my thread for each project I was sewing and it solved the issue.
Sep 03, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother vx790, my stitches are reversed ( top is on botom & bottom is on top )
It sounds like your tensions are out of adjustment. Your upper tension should be between 3-5 and make sure the tension in your bobbin case is not too tight as well. Pull the thread through the bobbin case and make sure it comes out with a small amount of resistance. If no resistance, tighten the tension just a bit, if too much resistance, loosen it just a small bit at a time.
Sep 10, 2008 | Brother LS-1217 Mechanical Sewing Machine
Zig zag problems
oh my i think you need to open your machine sir. i already tried it. kinda hard to explain it here
Sep 05, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
383 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
