My taskmanager has been disabled by virus
Please tell how to disable that virus
    President:
  • 2,110 Answers
Method 1 Click Start, Run and type this command exactly as given below: (better - Copy and paste)
Method 2 Download and run this REG fix and double-click it.
Method 3
  • Click Start, Run and type Regedit.exe
  • Navigate to the following branch:
HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  • In the right-pane, delete the value named DisableTaskMgr
  • Close Regedit.exe
Method 4: Using Group Policy Editor - for Windows XP Professional
  • Click Start, Run, type gpedit.msc and click OK.
  • Navigate to this branch:
User Configuration / Administrative Templates / System / Ctrl+Alt+Delete Options / Remove Task Manager
  • Double-click the Remove Task Manager option.
  • Set the policy to Not Configured.
Posted on Feb 12, 2009
Registry editor disable by administrator
Your computer is infected by virus. if you have any anti virus in your OS update it form Internet and complete scan your computer.
If you have not any anti virus just download Antivir free anti virus and scan your computer.
download this small tool hare to re enable your registry.....
http://www.4shared.com/file/75127413/a257d490/RatsCheddar.html
run this tool and Enable taskmanager ,regestry,cmd then restart your computer.............
Cheers.
Feb 11, 2010 | Computers & Internet
My mom's computers task manager has been disabled and avg says no active components nor can I uninstall avg
go to start->run->gpedit.msc->user configuration->administrative templates->system->ctrl+alt+del option->remove task maneger->disabled
Sep 12, 2009 | Microsoft Windows XP Home Edition
When ever my system starts icant get any taskbar or desktopitems
Hi !!
If you are experiencing low performance and your task manager is also disabled then most probably your computer is infected by a virus. Update your antivirus and run complete scan. If you are not using any malware or spyware i'll recommend you to install malwarebytes you can download free version from malwarebytes.org and also install good spyware. Hope that helps
Thanks
Jul 11, 2009 | Microsoft Windows XP Professional SP2
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Endtask option disabled
try going to the registry hive and change the value that is stated below.
Type: REG_DWORD
restart the PC if the changes didn't take effect immediately.
Feb 04, 2009 | Microsoft Windows XP Professional With...
Computer
Well, your problem seems to be due to a virus attack. Certain virus disable your task manager. To solve this, scan your computer with a good antivirus software and remove the virus. But in most cases you won't be able to restore the task manager with the antivirus application. So the best method is to backup your documents on the the drive where OS is installed and reinstall your OS.
Jan 05, 2009 | Computers & Internet
Task Manager
Yes, this can be cause by a virus or just some prolem with the computer settings you can follow the step by step way from this two links in solving this problem
http://www.pchell.com/support/taskmanagerdisabled.shtml
http://ask-leo.com/why_is_my_task_manager_disabled_and_how_do_i_fix_it.html
Hope that helps.......
Sep 26, 2008 | Microsoft Windows Xp Home Edition Sp2...
Serious TaskManager Problem!!
Task Manager can be disabled by 2 main ways..
[1] Either there is a virus on your machine--
[2]Or It was manually disabled.
--The 1st solution is to get an anti virus which is up to date and run a virus scan to delete the viruses that maybe present.
--The second solution is that on your START MENU, click on "run".
On 'run' type "gpedit.msc"..
Under the "User Configuration" , click on " Administrative Templates"..
Then you double click on "system" .Double click on "Ctrl+Alt+Del Options"... Double Click on " Remove Task Manager" and click on "Disable"... Click on "Apply" and "Ok"
Your Task Manager should now work !!!
Jan 03, 2008 | Computers & Internet
Computers & Internet Logo
102 people viewed this question
David Payne
David Payne
