Question about Sharp AR-5316 Advanced Digital Imager Copier
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
What does indication of F2 Error in Sharp 5316, what is the solution & how can this error can be removed
    President:
  • Sharp Master
  • 990 Answers
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Posted on Feb 12, 2009
    Problem Solver:
  • 7 Answers
Developer... its less than the usual amount... Use AVR if there are developer spillage
Posted on Mar 04, 2013
  • 41 Answers
Toner supply failure
1- change toner cartridge
2- change chip toner cartridge
Posted on Aug 29, 2012
    Problem Solver:
  • 6 Answers
F2 means you had installed wrog toer cartidge
soultions
reaplace tner ca.
Posted on Feb 19, 2009
SHARP AR5316 ERROR CODE F2
1- replace the toner cartridge.
2- replace the chip toner cartridge.
3- check and fix connection between toner cartridge and mcu pwb.
Jul 27, 2012 | Sharp AR-5316 Advanced Digital Imager...
While starting the xerox machine SHARP AR 5316 , indicator is showing 4 and blinking everytime, unable to take the printout
I'm going to guess that if you watch the display closely, it is alternating between an "H", and a "4". If that is the case, you have an "H4" error code. This is a fuser error and can either be a freak out from the machine, or an indication of something serious. I would recommend resetting the code and seeing if it comes back. To reset the code, turn the machine on and press "#" -> "Interrupt" -> "Clear" -> "Interrupt". Doing this should put you into service mode, where the display will show a blinking double dash (--). Enter 14 and press the green start button, just like you are trying to make 14 copies of something. At this point, the machine should restart itself and hopefully the error code will go away. If the error code does not go away, or recurs on a fairly frequent basis, I would recommend contacting a professional service technician.
Feb 22, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp Printer AR5316 error message 2U
EEPROM read/write error (serial communication
error)
Dec 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR 5316 is blicking h and then 2 please wat do i do...and pls how many copy can i make wit it in a day
An error code of H2 om a sharp 5316 indicates an open thermistor.A thermistor is a small electronic device that regulates temperature.You will need to call a copier technician.An Ar5316 operates at 16 copies per minute.Good Luck!
Apr 06, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Request service manual for sharp AR-5316
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7b292ec58f421b3b3b442c1437984770&q=Sharp+AR-5316
Apr 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
H2 error
An H2 is an indicator that the temperature sensing device is reading open, preventing the machine to warm up. There is only one way to correct this and that is to replace the thermistor, and that takes a technician. Not a hard job but a novice could get into trouble and make matters worse. Aloha, Bill Monroe
Sep 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
981 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
