Whether the printer will be locked?
Dear Sir,
How are you!
I want to know when the printer printing over 10,000 pcs within 1 month, whether the printer will be locked, and can't continue to printing?
Hoping to hear from you soon.
B.Rgds,
Eric Chow
  • 530 Answers
Hi im joseph in cebu philippines.may i help you. if you are using epson or hp printers. the memory span of your printer is already reach to its limitation and for that you need to reset or refresh your printer memory.it can be done through software.go to your printer assistance section or a pc printer provider near you and ask them to reset your printer memory.
Posted on Feb 12, 2009
Why does my Epson 2200 printer not even try to feed a sheet of paper when I run a status sheet from the control panel?
Hi!
Is the printer driver installed in a correct way and it is the correct version for your system? Try to uninstall it and reinstall it downloading the latest correct version from the Epson site!
If you wanna print a nozzle check try this:
1- Power the printer off
2- While holding the page key down, press the power key, DON'T release the page key, hold it down for 5-10 seconds
the printer will print the nozzle check
You can also do a cleaning cycle by holding down the ink key untill the cleaning process starts.
Did you try this on other PCs?
Let me know! :)
Best regards!
Jul 22, 2016 | Epson Stylus 2200 InkJet Photo Printer
Metro pcs unlock code
Hi whether you want to unlock your samsung mobile from network lock to freely use it with metro pcs sim ..Then you can purchase network unlock code from sites like SimpleUnlocking.com for affordable cost ...You first check that whether the code is available for your mobile model ,country and network provider ..If yes then pay for it and unlock your phone ..
Aug 03, 2014 | Samsung Cell Phones
Print document
you need to check:
1. Whether you can print from another apps(Word for ex)?
2. Whether your printer is set as default?
other actions depends on these answers
Jan 10, 2014 | HP LaserJet CM1015 MFP All-In-One Printer
Why will my printer not print a job but if I restart my computer it will print?
FIRST I WANNA KNOW WHETHER IT IS INSTALLED OVER THE NETWORK OR NOT. IF YES CONFORM WHETHER WHETHER IP ADDRESS IS STATIC OR AUTO. IF IT IS INSTALLED IN AUTO IP MODE REGISTER THE IP ADDRESS IN THE DHCP SERVER.OTHRWISE INSTALL THE PRINTER USING STATIC IP.
Apr 08, 2011 | Office Equipment & Supplies
How to print two side on a single sheet sir i want to print on both side of the paper how can i sir
Step 1
On the File menu, click Print.
Step 2
In the Print dialog box, in the Name list, select the printer
that you want to use.
Step 3
Click Properties.
Step 4
In the Properties dialog box, look for information that indicates
whether and how your printer supports duplex printing.
Oct 27, 2009 | Samsung SCX-4300 Monochrome Laser...
The light is blinking
hi,
1.Please check whether drivers are installed.
2.check whether printer is printing the test page.If not issue with printer.
3.If printing the test page then please reinstall the printer and then check.
Any troubleshooting you followed or any error message Let me know.
Jul 06, 2009 | HP DeskJet 3940 InkJet Photo Printer
Data light flashes , documents won't print.
this is not a network problem.because machine is receiving documents thats why light is blinking. check the paper in the tray whether they are of correct size, change the paper size from computer, or call your tech service rep it may be due to usb cable or faulty network cable, or it may be the problem of main communication board of photocopier machine.
Feb 10, 2009 | Konica Minolta bizhub C351 All-In-One...
Printer has completely quit printing color with new ink installed
In order to determine whether this is a hardware or software problem there are several steps you can take:
1.Download and install the most recent printer driver from Epson
2. Try printing out the nozzle check pattern using the Maintenance Utility. This bypasses the printer driver and allows the printer to use all cartridges to print out the patterns. This will indicate whether there are clogged heads and whether or not it will print color at all. Gaps in the patterns indicate clogged heads and you need to run the Head Cleaning utility once or several times.
3. If you get color patterns from the nozzle check (whether or not the patterns are full or have parts missing) you need to check to see if the default settings for the printer have been set to "Black Ink Only". Right click on the printer icon and select "Printing Preferences". Click on the "Advanced" button in the lower right corner and after the popup, look on the left side and see it the "Black Ink Only" box is checked. If so, uncheck it and while you are there uncheck the "High Speed" box as well. This way you don't have to deselect it in the printer dialog each time you print, especially if you are looking for a quality print each time.
4. Try the printer on another computer if you get color during the nozzle check to see if the software is corrupt on your computer.
5. If you get no color patterns at all when doing the nozzle check, it would appear that you have a hardware problem within the printer. It would be unlikely that all the colors would fail at the same time due to severe head clogging.
Hope this helps in some way.
Oct 07, 2008 | Epson Stylus C86 InkJet Printer
Word 2003 doc spreads to 3 pages
You probably don't have the same fonts installed on the new machines, and Word is substituting the ones you are using with a close alternative.
Aug 26, 2008 | Microsoft Office 2003 Pro (269-07387) for...
HP Officejet 5610 series printer problem in printing
Can you please restart your computer with your printer connected. Check for cartridge whether it has adequate ink.
try printing again and if it refuses to print just come back and advise me.
Thanks
Dec 10, 2007 | HP Compaq Presario V2000 Notebook
62 people viewed this question
k24674
jasbo
jasbo
