Question about Canon FAX-JX200
I have a canon fax jx500
It will not print faxes and it says auto print off and REC'D received in memory, and will not go back to its normal mode. Can you help me please ?
  • glennice Feb 22, 2009
    I have a Canon FAX-JX500 and there is a message on the small screen that says "REC'D IN MEMORY". I have tried turning the machine on/off, pressing the on/off button just once, adjusting the paper and pressing the start button. But nothing works. What now? Maggie
  • Pablo Lorrio May 19, 2009
    i have pressed it once,but it still says autofax off,with faxes in memory and prints them when it wants
  • 318 Answers
Turn auto print on by pressing the on/off button once.If you hold down the on/off button the macine switches off,if you press it once it switch beteen auto print on or off.At first I was also confused by this setting.
Posted on Feb 20, 2009
JX500 says "rec'd in memory" and "auto print
I can email you the user manual for future use. LBrown18062@hotmail.com Lawrence Brown
Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [up] or [down] to select , then press [Start/Copy].
3 Use [up] or [down] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Sep 29, 2011 | Canon FAX-JX200
My fax machine is in auto print off mode how do i switch it to auto recieve mode
Hi; Receiving to Memory Temporarily You can enable memory receiving feature temporarily. Received faxes will not be printed automatically.
  1. Press [ON/OFF] to select <AUTO PRINT OFF>.
  2. ??? The fax starts receiving documents in memory.
  3. ??? To cancel, press [ON/OFF] again.
  4. ??? When <AUTO PRINT OFF> is cancelled, received faxes will be printed automatically.
good luck
Oct 15, 2010 | Canon FAX-JX200
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
My canon fax jx500 is saying autoprint off and we are unable to receive any faxes. how do i switch it ''on''. can't find it in the menu anywhere
hi rebecca you have to Press the on / off switch once, this will switch the machine's fax to auto receive mode. Press and holding on / off switch causes it to power off.
Dec 02, 2009 | Canon FAX-JX200
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Recorded in memory keeps flashing on my Canon JX500 fax machine! How do I remove this?
Press the ON/OFF button once and it will switch to auto print on or off.Faxes will be printed directly and not kept in memory.
Aug 25, 2009 | Canon FAX JX200 Fax / copier Plain Paper...
Canon fax jx500 in non print receive mode, how to make it print when it receives
Press the on/off button, do not hold down. Pressing on/off button enables or disables <auto print> feature. Holding on/off button for several seconds shuts machine down.
Aug 18, 2009 | Canon Office Equipment & Supplies
I have a Canon Fax-Jx300 and it keeps saying "Rec'd in Memory"
Normally on this machine the auto print is set to off,press the on /off button ones untill it shows auto print on.
Feb 18, 2009 | Canon FAX-JX200
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Canon FAX-JX200 Logo
897 people viewed this question
old marine
old marine
Corne Viljoen
