Question about Sony Audio Players & Recorders
I can't get bass thru the spkrs
I can only get bass when the sub-woofer is switched on....
Amp is a Sony STR-KG800 Spkrs are Mordaunt short Avant 904's....
I'm using dvd player (HDMI connection) as cd player and I've tried connecting using normal audio connection but no joy...can anyone shed any light on this ?
Thanks in advance is u can
  • iangittins Feb 13, 2009
    thanks for getting onto this one....
    The amp does not have that facility
    The amp does not have that facility unfortunately....I've just spent an hour or going thru the various menus of both amp and dvd player but no joy
  • 336 Answers
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Posted on Feb 12, 2009
No sound from sub
  1. Are the stereo speaker wires run to the subwoofer and out to the stereo speakers
  2. Make sure the notch filter is off
  3. Refer to the manual on line: http://www.manualslib.com/manual/105794/Mordaunt-Short-Ms909w.html?page=7#manual
  4. READ THE MANUAL
Nov 12, 2013 | Mordaunt Short Aviano 7 - Powered...
Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Aug 02, 2012 | Audio Players & Recorders
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
I Have a buzzing mordaunt short avant 916i cone
Hiya, its the cone. The former is touching the magnet inside. Realignment is really tricky and dont know many people who can do that so you may either have to live with it or see if someone can recone it in your area.
Best of luck
Jul 15, 2009 | Audio Players & Recorders
I have 2 10inch spekers in a box that just stopped playing the bass! can anyone help? ive checked the fuzes!
If the fuses are good , this could still be a prob with amp, check spkrs with a ohmeter(cheap one from the Shack or anyplace) by touching both leads to spkr terminals, disconnect spkrs first.Have ohmeter set to ohms Rx1 and you Test amp out put by connecting two spkrs that you know are good. Good luck and please rate this answer,thanks.
Apr 06, 2009 | Mac-Audio Compact 220 Car Subwoofer
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
Zone two spkrs will not play
How many sorround speaker connected to the subwoofer?
Feb 23, 2008 | Onkyo TX-SR601 Receiver
Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Jan 22, 2008 | Audiovox BA100 Car Subwoofer
Mordaunt Short Avant 309i subwoofer set-up
Lots of ways. To set it up properly you will need a decibel meter, Radio Shack makes a nice one. With the meter volume can easily be set as well as phase. I'm assuming frequency is the crossover frequency, generally set at 80Hz. This one involves some trial and error as I am not familiar with your speakers. Don't know much about the notch filter. A good resource for setting up subs can be found at: http://www.hometheatershack.com/forums/bfd-rew-forum/index3.html
Jun 18, 2007 | Mordaunt Short 309W Subwoofer
165 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
