Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
No Dispay, No Beep
My PC is not working when i unplug the RAM then computer give an RAM error beep, but when i plug the RAM on motherboard then nothing happen no display, no beep, the RAM is Ok working in all other PC, please solve my problem
Mother Board : INTEL 845 EPI
  • dibongs Mar 09, 2009
    No display, at 1st I thought it was a monitor cable, but it was not, so I then tryied to install a screen card(or video card) still on display! every thing is working proparly except the screen card on board!
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Can you clarify what not working means?
  • 135 Answers
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Posted on Feb 17, 2009
  • ted dux Feb 19, 2009
    Or your RAM is incompatible/damaged.
Boot failure, beeps and no display
Hi.
Do this solution first in the motherboard only processor installed need no memory.then power on your PC.if your motherboard no continues beeping.that need replacement of parts specially capacitor
leakage,became big or burn parts.
See beeping code.
Beep Code:
Description of Problem:
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
Jun 17, 2011 | Dell Motherboard For Precision 470...
My mother board is not giving any beep sound. When i power on the PC system looking working bt no display. I chk processor nd RAM bt they r working on another board.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 13, 2011 | Intel D101GGC Motherboard
My motherboard gives 8 beeps and shows no video, I tested with several video cards and gives the same result. when the computer beeps (normal as it recognizes that although the bios), then emits...
Continious beep codes are caused by the memory (RAM). Try reseating your RAM just plug it out clean it then put it back in. Or try the other memory slots. Just transfer your memory to the other slot if you have an available slot on your motherboard. Or simply buy a new memory (RAM). Just make sure it is compatible to your motherboard. Beep codes means the computer is not reading the memory (RAM) properly. There is no post and no video in your computer because the RAM is not working properly.
Dec 19, 2010 | Intel ASRock Penryn1600SLI-110dB LGA 775...
The ram went in machine so i replaced it with the right ram and it makes now when i switch on a beep.... beep beep then a paluse then a single beep and it repeats and the compture wont turn on at all
Hello
Completly unplug your pc from the wall.
Open up the case and remove all sticks of ram for a minute.Set aside the new or the ram you replaced.
Put ram back in leaving out the new one.If pc starts and no beeps,then repeat process but this time put in new ram along with old.
Be sure ram is properly seated,ive had this problem myself due to not having the ram in all the way.
Restart pc,if you still have a beep then you either have the wrong ram or it is in the wrong slot.
If there are 4 color coded ram slots say white blue then white blue be sure both sticks are in white or blue slots but not side by side.
Dont forget to plug your pc back in.
Good luck.
Dec 14, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Compaq Pentium 3 motherboard 187498-001
Here's the compaq beep codes
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07107&cc=us&lc=en&dlc=en
As you can see your codes are not listed so I would presume you have the Award BIOS and your problem comes under "Other beep conditions" = memory errors.
Sep 17, 2009 | Compaq 187498-001 Motherboard
Beepcode: single beep every 2 to 3 seconds continuous
Try taking out the ram and reinserting it also anything that is in the PCI Card slots.. other solutios is take and unplug each device and see if the boot up changes it will sometimes give a read code it might help eliminate the problem
Jul 26, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
Asus Motherboard Constant High POST beep
long beep - memory bank is not plugged well, or broken
continuous beep - no power, loose card, or short.
Aug 01, 2008 | ASUS P4S800-MX Motherboard
One long beep.
  1. Leave the memory slot closest to the processor empty and try booting again. Award bios 1 long beep is memory error as the first 64K of the ram stick closest to th processor is accessed first. since you have tried different ram in different locations, let's rule out the board.
  2. If that doesn't solve anything try a different power supply. Sometimes (Phoenix) gives a long beep when system board or power supply are bad.
  3. Now if nothing else has worked it is probably tour mother board.
May 16, 2008 | Abit KN8 Ultra Motherboard
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
173 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
