Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
The belts come off, its a hotpoint aquarius wm63.
Basically how do i put the belt back on and is there somewhere that will show me a picture of how its all supposed to look.
  • leonie_griff Feb 12, 2009
    thanks. thats now done but the machine is very noisy on a spin cycle. where do i chack to look for anything to fix back? Leonie
  • Hotpoint Master
  • 3,463 Answers
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Thanks.
Posted on Feb 12, 2009
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How to take bearing out of aquarius model wm63
The information for dismantling and rebuilding a Hotpoint WM washing machine is all in the workshop manual including wiring connections
Mar 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1100 wm63 very noisy spinning
Remove rear cover of washer.
Remove drive belt.
From inside the drum, spin the drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then possibly motor bearings noisy.
Hope this helps Thankyou.
Nov 27, 2009 | Hotpoint Washing Machines
Hotpoint aquarius tumbler not turning belt was off so put it back on and still tumbler not turnig altho bottom motor is working
the belt didn't get put on the idler pulley and does not have enough tension to turn drum, recheck belt routing
Nov 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius belt slippped
Hi.
It sounds like your washer may have a major problem.
If it was so noisy, it sounds to me as though the main drum bearings have gone, or the motor bearings, that being the case, I woukld recommend that you do not use the washer until it is checked out.
Hope this helps!!!
Nov 14, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Changing belt
the belt seems to be too short, how can i get the belt on the motor and the pulley on the drum?
Mar 29, 2008 | Kenmore 44072 Front Load Washer
Hotpoint aquarius 1300
it takes a fitting stap to fit but can be put back on by hand little tricky but can be done no probs
Mar 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
213 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
