Question about Bunn GR10 Coffee Maker
Basic Bunn Coffee makers will not light up
I have a black and white Bunn coffee maker and filled them with water and the light will not go on. Apparently no electricity is getting to the Bunn coffee maker. Now what? Have water all over my kitchen!
  • Gord Thurston May 11, 2010
    do you mean that your brewer is leaking? or is this because you filled them too full? and did you make sure that the switch on the side of the tank is on?
  • 189 Answers
Please get the model and date code off the bottom of your brewer. Contact customer service with this information and we will be happy to assist you with this issue.
Posted on May 19, 2010
    Problem Solver:
  • 7 Answers
Look on the left hand side down by the bottom there is a switch try that.
Posted on Jul 08, 2009
4 Suggested Answers
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
SOURCE: my bunn coffee maker leaks, were can I get parts?
You can call Bunn Home division in Springfield, IL at (800) 352-2866. They have a kits which you can try at no charge. If that does not work, they will replace your coffee maker at discounted price provide you send the old one in. On the bottom of your coffee maker there is a modle number which they need on a white tag. .Hope this helps
Posted on May 22, 2009
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Brand new bunn, can't get it to make coffee
if the coffee pot does not work right, take it back and get another one...
May 11, 2016 | Bunn GRX-B Basic 10-Cup Home Coffee Brewer...
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
Moved coffee maker to new location...208v good ...will not make coffee or produce hot water...
If it is a 125/250v machine make sure you have 120v between the red and white wire, or the black and white wire on the incoming block.
Jun 23, 2010 | Bunn (279000002) Coffee Maker
Not all water comes through filter
2 cups white vinegar in reservoir, run full cycle, let cool, discard vinegar. Fill reservoir with cold water, run full cycle, discard water, let cool. Repeat clear water cycle.
Jan 22, 2010 | Bunn NHB Coffee Maker
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
Water wont come out of my bunn coffee maker
The first pot of water you put in the coffee maker just fills the water tank which is then heated up , once it gets to temperature you then pour second pot of water this pushes the hot water out of the tank through the coffee grounds into the waiting pot. This way you can make coffee faster than a regular coffee maker.
Jun 02, 2009 | Bunn GR10 Coffee Maker
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
May 06, 2009 | Bunn NHBX-B Contemporary 10-Cup Home...
Bunn GR10 Coffee Maker Logo
225 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
