Question about Toshiba DP80F Printer
Toshiba dp80f-Drum unit warning
Once the "Drum Unit Warning" appeared on the screen, I replaced the drum with a new one, but the message is still on. I tried several times to re-install it, I also made a test using the diagnostic program but the message doesn't disappear.
Is there any command in the menu that solves this problem?
Menu, 5, 2, 0, 4, 1, enter
This will reset the counter for the drum unit.
Posted on Jun 14, 2010
    Scholar:
  • 136 Answers
Their is a manuel reset for this fax Machine,You can purchase a Serivce Manuel or have a Service Tech do it for you, the drum needs to be reset this is a job for a Service Tech , get the manuel your better off.
Posted on Mar 08, 2009
My machine don'y copy, I receive message:Now warning up. Ready to scan
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Feb 26, 2016 | Konica Minolta bizhub 750
When I get the warning for the drum reset on our 170F do I need to replace it right away or should I wait til it stops working? If I wait how long will it usually be?
This is an advance reminder for you to order a new drum, you do not have to replace it until it asks to do so. A drum unit is rated for 20,000 pages (5% coverage), it depends on your usage, if there lots of graphics of dark color, you have to replace it before it expires. You can reset it, if there is no quality issues. Procedures:
[x]-key to press, {{ Display on the LCD}}
[Menu], [5], {{5 Default setting}};
[2], {{2 Scanner & Printer}};
[0], [4], {{04 Reset drum counter, 1=Yes, 2=No}};
[1] {{Reset Drum Counter, are you sure?}};
FYI: I would recommend that you put a label "Drum reset" on the drum unit, remind yourself, that you must replace it, once you have a quality issue.
Nov 01, 2013 | Toshiba e-Studio DP170F Plain Paper Laser...
We have a Toshiba 170F fax machine that is no longer under warranty. I need instructions on how to replace the drum.
the drum & its cover is one unit
just remove the toner cartridge & put it in the new drum unit cover
May 11, 2011 | Toshiba E-Studio 161 Copier
Even after changing the toner, its shoing the drum unit warning
this warning is for replacment of drum, not for toner.
so please replace drum unit and resset drum counter with the help of installation docs available with new drum unit.
Apr 18, 2011 | Toshiba DP80F Printer
just install new drum unit and perform this proggrame MENU-520411-START-STOP
Feb 20, 2011 | Toshiba DP80F Printer
The printer screen shows change parts and on the wlan computers connected to it says that the drum end soon and that panics me a lot as i paid a lot for this damn computer
Did you recently replace the drum and the warning is unexpected?
Why does the message "Drum End Soon" continue to appear on the LCD after I replaced the drum?
Description:
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  1. Press Menu on the Control Panel.
  2. Press the Up or Down Arrow key to select Machine Info..
  3. Press OK.
  4. Press the Up or Down Arrow key to select Reset Menu.
  5. Press OK.
  6. Press the Up or Down Arrow key to select Drum.
  7. Press OK.
  8. Press 1 to reset the drum unit counter.
You can use this procedure to reset a drum in order to continue to use up the remaining 'life' of the drum; recognizing that you will need to replace the drum when you start having print quality issues.
You may find this site very useful.
Trust this is helpful. Please vote.
Dec 31, 2010 | Brother MFC-9840CDW Laser Printer
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
In the display it says drum unit warning. What do...
Try removing the drum unit with the fax machine turned on.After reinstalling the drum check the display for a "new drum?" message.Answer "yes" and the mashine will reset the counter
May 16, 2010 | Office Equipment & Supplies
Drum unit
It's time to replace the drum. If you don't, it will stop working soon.
Oct 17, 2008 | Toshiba DP-85F Fax
Toshiba DP80F Printer Logo
1,496 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
