Back to:
Tags:
Garmin zumo  550 GPS Receiver
Magellan Crossover GPS Mount (by 2 users)
By Bomber - usenet poster
I just got the Magellan Crossover GPS. I really like it.
I notice that their is a connector on the bottom of the GPS unit. I
assume it contains antenna, power and other functionality.
Does anyone know if their is a car mount that takes advantage of this
connector? It would be nice if, for example, the power adapter could be
plugged into the mount and not directly to the unit.
David Chamberlain - ASAPM Moderator
| Support for anxiety or panic disorders. Check us out! |
| alt.support.anxiety-panic.moderated # |
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by han808, posted on Oct 31, 2008
I have the same question. Perhaps I just skimmed and didn't read carefully ,but What IS the serial pinned slot of the bottom for? There is no reference to it in the manual as other have stated. Links ?? Thanks folks
Best Solution
posted on Aug 01, 2007
Helpful (85)
Bray
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
<snip
Okay, that would be a nice thing. The Garmin zumo 550 has a nice mount
that the GPS snap into and mates with a multi-pin connector to pick of
the power, XM receiver, and other optional at extra cost peripherals.
That is a nice unit and is getting good reviews from buyers. The MSRP
on the zumo 550 is $1,076, street prices are down around $700 now.
The MSRP on the Crossover is around $600 but amazon is already selling
it for $419 so it is going to be getting quite a bit of attention. The
mapping it comes with will be an attractive selling point. But Magellan
really need to be presenting the details and info in a manner that makes
it easier to figure it all out.
Garmin had two StreetPilot models (2620 and 2660) that used 2GB
microdrives to store the map data. But they had a lot of problem with
them failing in service and most people seemed to think that they simply
weren't up to the vibration and temperature extremes. Both models were
discontinues pretty quickly.
I was a long time Magellan user on the Meridians and liked their topo
mapping very much. If you're familiar with the USGS 1:24k Quad maps,
thee Magellan Topo 3D mapping came out to about 1:40K in comparison.
Garmin's package is 1:100K (some Garmin 24K mapping is available for
some National Parks).
The USGS maps have always shown most older paved roads and highways on
them. They were normally just shown as two parallel solid black lines
so that is probably what you are seeing. The roads on USGS maps will
lag way behind the proprietary street/highway mapping packages as far as
completeness and accuracy.
Garmin's topo packages have been embellished some in that major roads
and highways are show as heavy red lines. And I think on some packages
(the 24K packages only?) those roads and maybe even trails are vectors
and can be used for autorouting.
<snip
The Magellan accessories page shows two mounts. A "Replacement Mount"
and a "Rugged Windshield Mount". The latter is a RAM mount and that is
a very well made and much more rugged mount. There is only about $5
difference in the prices on the two, if you have to replace your mount
I'd highly recommend the Rugged Mount.
<snip
I can see it as an attractive unit, I'm looking forward to hearing more
about it here as time goes on. I don't want to own one of every kind
but am mildly addicted to things GPS and like to read the feedback from
people that are using them.
Yep, there it is. I just had to jump through about four hoops and I
could read all about it. Interesting unit as I read about it.
It is a MP3 player and also a photo viewer.
It seems to have some of the essential navigation features. The manual
does not have an index, that is kind of silly.
It will record tracks in the marine and topo navigation modes but not in
the automobile navigation mode? What's up with that? Car drivers like
to see the when and where details later too.
Magellan gives you a desktop application that does some things like
managing MP3 files and POI but it does not appear to have the mapping on
it and cannot be used for planning routes and uploading them to the GPS.
Maybe there are fewer people now that want to do that but many of us
consider having a companion software and the same mapping on your PC an
essential part of using a GPS.
You're a lucky guy. You had lain the groundwork for what could have
turned into a tragedy there. And the GPS helped bail you out. You
ought to tell Magellan about it. "My new Crossover saved my life the
second day I had it...".
And tell them about the software glitches too.
One of the things that haunted Magellan users under the ownership of
Thales navigation was the general lack of development and updates on the
unit software. If it did not get fixed in a few years it would never
get fixed.
Jack
Jack Erbes in Ellsworth, Maine, USA (jackerbes at adelphia dot net)
(also receiving email at jacker at midmaine dot com)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Magellan Crossover GPS Mount:
I don't want to Accept this solution
Solution #2
Helpful (85)
Grant
Rating: 0%, 0 votes
It came with an AC adapter, a vehicle adapter (which I didn't expect), a
base, suction cup mount, stick on disk so you could reliably mount it to
the dash, etc. I was just wondering if their was a mount that USED the
base connector so that power, antenna, speakers if you wanted them, etc
wouldn't all have to be plugged directly into the unit.
The Magellan site sucks pretty bad, I agree.
Interesting, I didn't notice the hard drive part. It does have a LOT of
map data. And supposedly 30ft resolution topo maps will be available
soon. The topo maps are interesting because they also include all the
roads, down to roads that looked a lot more like cow paths to me.
I was wary of a suction cup mount. So far (2 days I've had it) it's been
OK, although it bounces a bit on our rough roads.
I was looking originally at the Garmin's and didn't plan on spending as
much money as I did. But I saw either street nav products, or hiking,
topo map, etc products, and wasn't happy that I couldn't get both,
because I do both, in one unit. When I stumbled on this unit I bit the
bullet and went for it.
User manual is in the support pages.
So far, I'm happy with it. But I've only had it a couple of days. I have
had one unexplainable lockup (it just stopped reading the position, even
though the satellite screen showed plenty of satellites) and I had to
reset it. I also encountered a bug where if you zoom out the topo map
too far the unit locks up and reboots and then won't show you a topo map
anymore. I assume some programmer forgot to do a test for the upper
limit on the map zoom.
I managed to fix that by doing a POI search and having it display it on
the topo map which caused the map to re-zoom back down to the lowest level.
It saved my ass yesterday when I managed to stick my car into a snowbank
on a pretty remote forest service road. The unit identified the road I
was on (road wasn't marked), and after about a 2 mile hike I managed to
get enough cell service to call for assistance and actually be able to
tell someone where I was.
Thank You!
Solution #3
Not Rated (0)
Riddle
Rating: 0%, 0 votes
Does that not come with a mount or power cable or any other accessories?
The Magellan web site for it is pretty uninformative as far as manuals
or included accessories:
So it comes with both street and highway and topo mapping preloaded to a
4 GB hard drive. I hope that they have better luck with hard drives
than Garmin did.
Has a SiRF III chip set though. It is good to hear that Magellan is
finally doing something about their hardware.
And they are bragging about it being waterproofed to IPX4. I wonder if
they have noticed all the other go anywhere/do anything GPS receivers
are waterproofed to IPX7?
I clicked on accessories and see three items. Then I click on the
little red "View All" thing (wondering how much there is to say about a
power plug) and find a *whole* *page* of accessories including some mounts:
I finally figure out how to get a close up and guess what? The mounts
are made by RAM! Holy bat crapman! Those are good mounts! Why aren't
they telling people about the RAM mounts and waving them in the faces of
the tire kickers on that web site?
The Magellan web pages make me a little crazy too. I think they have
them on a server in India along with their tech support people. I have
a good T1 class cable connection but feel like I'm back on a 26.4K dial
up connection when I visit their pages.
I did that demo and it was like watching an ant race.
I'm not trying to be hard on Magellan, I want to see them come back and
scare Garmin but they are going to have to win over some consumers to
beat them in the GPS market. They need to clean up their act and get to
work on selling this stuff.
Where are the user's manuals? Did they make that so hard to find that I
missed that too?
Anyway, welcome back Magellan! Now come on and give Garmin a scare!
Jack
Thank You!
Can you Help with these GPS Devices problems?
I paid for 3 yrs, but still getting the same as if I havnt...
Took out Battery for several minutes, it will turn on go...
Connected zumo to laptop for map upgrade, now it will not...
Thanks for your previous fix. I still cannot download...
i have softwher garmin for navigation when i instoolet the...
Loading problems.
Repair Service
Find GPS Device Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
