Question about Sharp AR-5316 Advanced Digital Imager Copier
Error report sharp copier ar 5316e, an error report, the sign showed that the marchine is set work, keeps blinking and others key are not responding please help me. i ll be glad if you can solve my problem.
  • fareedasaleh Feb 13, 2009
    thanks, but the problem is still on so help.
    Gooday.
    Yes the light is bilnking continuesly, i mean the toner indicator.
    President:
  • Sharp Master
  • 990 Answers
Hello sir; Let's do a reset;
1, press "#","interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if this is helpfull, please give me a good rating.
Posted on Feb 12, 2009
  • Everett Lin Feb 13, 2009
    Hello sir; Sorry about reset can ot take care your problem, let's start from begining, tell me what's message dispay on the window, have any code, or any light blinking on which indicator, please let me know. thanks.
My sharp ar-5316e error code CH please help me
Hope you are fine, ch are in two forms steady one and the blinking ch.
Steady CH
This is associated with door switch for either front cover or side cover. Check that the front cover of the copier and the right side is well closed.
Blinking CH
This is associated with the toner cartridge or the developer unit not being sensed by the machine. Make sure that the developer unit is well locked in the machine. Pull out the toner cartridge and insert back with some force into the machine, it should clear this sign. If it does not, replace a new cartridge Sharp Ar016ft and you are done. Good luck.
Nov 23, 2010 | Sharp AR-5316 Advanced Digital Imager...
MY SHARP PHOTO COPIER MODEL AR 5316 WAS PROBLEM WHEN I PRINT THE PAGE THE ERROR IS COME E7-11 NO BUTTON WAS WORK PLS GIVE TIPS ITS URGENT SIR
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 01.duplex model memory error
02.LSU trouble
03.shading trouble (black correction
04. shading trouble(white correction)
05. shading trouble
06.Abnormal laser output
Jun 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
All buttons not function and cntiniosly showing 4 and H
You have fuser problem, try reset by pressing [#] [interrupt] [c] [interrupt] [1] [4] [start]. The machine will goes off and on again, if the problem persists you should replace the fuser lamp
Mar 30, 2009 | Sharp SF 2020 Copier
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Feb 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
