Question about E-Machines eMachines Desktop PC
Emachine tower won't turn on
I have an Emachines desktop. I have checked that there is power to the case, reseated the cables, there is a small green led that is lit up on the motherboard (Its always on) so I'm assuming its not my power supply.the power supply fan and the case and cpu fans start then all the fans stop with in seconds of start up,I jumped the molex connector and the PS fan will stay on.I tried jumping /shorting the two pins on the MB where the power switch connects and nothing.
But no matter what I do the computer will not turn on from the switch So do you have any Ideas?
  • daddywoofdaw Feb 12, 2009
    what is the SMPS?
    what is the SMPS?
    Sergeant:
  • 276 Answers
First check the power supply or swap another.
remove ac power cable and clear the cmos jumper.
connect only power 20 or 24 connect and test power on. no off? (no video because no power to cpu by 4 pin or 6 pin connector)
plug 4 pin connector and test power on. if on and off check cpu power section (mosfets) if burned one pls remove ... you can test short by touch the mosfet by finger (burning heat)
Posted on Oct 11, 2016
    Genius:
  • 1,913 Answers
Smps it is on cpu. where u connect power supplty cable it is 1 square box.it is on top[ of cpu back side.
Posted on Feb 12, 2009
    Sergeant:
  • 191 Answers
Change your SMPS .it is faulty.
Emachine ET1850 model when turn on no display picture.
Check ALL monitor cables, reseat connections. Have you done any hardware or software updates? Graphics Updates? Do you get anything at boot? Just no signal? It sound like a hardware issue, Graphics. Support for your machine can be found here: http://support.gateway.com/us/en/emac/product/default.aspx?modelId=2064 You could buy a PCI e x16 Graphic Card . Better ,faster Graphics. First, check VGA connections, reseat, check for bent pins. Try another cable and monitor, to verify.
Jan 02, 2013 | E-Machines eMachines Desktop PC
Emachine T5234 beeps 5 times and won't turn on
5 Short BeepsYour motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
Aug 15, 2012 | E-Machines eMachines Desktop PC
My computer shuts down
problem with you either capacitors on motherboard or capasitors in smps, 80 % it becouse of capacitors in smps, it's not providing sufficient power to motherboard.
Feb 26, 2011 | E-Machines eMachines Desktop PC
Reset emachine t6532 bios
Open up the tower, (computer unplugged of course), remove the small coin shaped battery, leave for 1 minute, re-insert and power on.
Jan 06, 2011 | E-Machines eMachines Desktop PC
My emachine t5246 just beeps when i turn on why?
This could be a memory dump issue or a parity cheksum issue
what you need to do is open up the tower and take the memory strips out and reseat the same and reboot the system
Dec 26, 2010 | E-Machines eMachines Desktop PC
I have an emachines T1440 desktop. the front face of the machine is broken, the power cord, and the wires from the power cord to the power supply box. What type of case or tower can i use the remaining...
Luckily, eMachine uses a generic system board. You can purchase a case from any computer store. The only thing to watch for is the plate in the rear of the motherboard, make sure it matches your ports. Again I believe you can use the one from your eMachine.
Nov 12, 2010 | eMachines T1440 PC Desktop
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Tower won't turn on
hi try to put the monitor lead in the tower, the leads are both the same, the fuse might be out in the tower lead.
Mar 28, 2009 | E-Machines eMachines Desktop PC
My PC Will Not Start
Hi wah4pay,
this white USB plug has nothing to do with the eMachine not starting up. My guess about the white USB is it might be for your printer (If you have one). USB cable supplies 5volts DC only which it not enough to power a desktop or laptop PC.
As far as why the PC will not start, check the back side of the tower. See if the main power cable is plugged into the power supply & it also is plugged into a working wall outlet. There is a small RED slide switch on the back of the power supply. Make sure you can see the numbers & letter, 115v.
If the switch is set to 230v move it to 115v. Try starting the PC.
See this mini video of the T3646, you'll notice there are two USB ports on the back side of the PC & two more on the front of the case:
http://reviews.cnet.com/desktops/emachines-t3646/4505-3118_7-32924902.html
If this is a new PC, it most likely came with a one year warranty. You should call eMachine for free support. Your documentation will provide a phone number for support.
If your eMachine is not new or no longer under warranty let me know by posting here & I'll give you some other possible suggestions that may help get the system to start. Please include the year bought & month
Mike
Oct 28, 2008 | E-Machines Computers & Internet
I have a emachine model t3958
try to reseat the power cable of the computer and power it on again
Jun 24, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
423 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
