Question about Biostar NF325-A7 Motherboard
Can't seem to flash the BIOS
I'm having a hard time trying to get my bios working again. Originally I had flashed the bios with what i think now is the same bios that it had only I had done it from windows, which now I know was a mistake, and 2 that i had selected AMI instead of award which is what my bios is. Which btw is a BIOSTAR NF325A7 V1.1 .. Anyways.. so now I get the Boot Block error, saying BIOS ROM checksum error.
I have been using a DR DOS formatted floppy with AWDFlash 8.82 and the bios which was originally saved when I had done it from windows which is named nf325a826.bs
If I proceed through with AWDFLASH. I can get it to go [still takes a minute or so to start] But, once it starts to write the BIOS it will stop and say FLASH ROM IS WRITE-PROTECTED. <-- Now I've read that this is because of a write protection setting in the BIOS. So I'm really stumped.
I have actually gotten it to flash once. It actually said flash complete. But when I rebooted I got the same bootblock error. So I pulled the battery out and set the jumper to clear the CMOS. I left it there for a couple of hours hoping that it would bring it back. IDK, I read somewhere on some site about having to leave it there for like 24 hours or so for it to be effective. Anyways case in point. I'm still at the same spot and want some help.
Have it done it right just haven't finished it somehow or have I not gotten anywhere?
P.S.
All I have connected is the PS connected to the MOBO, one RAM module, The CPU and Heatsink seated and working; and a floppy drive.
BTW I'm aware that there is a BIOS upgrade function in the bios.. however I didn't know that prior to flashing and now I can't get there anymore.
My english is not perfevtly. I had this same problem. I use Uniflash, russian program to flash bios. It's working. http://www.rom.by/book/Uniflash
Posted on Jun 14, 2009
  • 42 Answers
This probably isn't what you want to hear but I would recommend just contacting the manufacturer and getting a replacement at this point. You will be spending a lot of time and be very frustrated in the end. Trust me.
Posted on Feb 12, 2009
Sony vaio vgn-s2hp did a restore - cannot find operating system message - replaced drive, same message. Bios is corrupted, how can I fix this?
1st-What O\S (win-xp, vista, # 7,etc.) did you "RESTORE" ?
2nd-Why did you mess with the BIOS. ? Did you understand that the BIOS is the INSIDE\PHYSICAL part of the laptop and NOT the Operating System [O\S] Windows_xp, vista, #7 etc.etc.
3rd-That "cannot find operating system" could be something as simple as the BIOS was RESET by something as a 'glinch', electrical short, suddenly turning off ( not that you did it! ) of laptop , lighting while you were working ( ALMOST ALWAYS... when the computer is writing to hard drive [H\D] with laptop
The BIOS could not see the H\D because is was changed by sudden electrical surge.
That you replaced H\D, you will have to REINSTALL the O\S again.Because I will assume that you brought a DIFFERENT type of H\D [ maybe something with more GB?, different model H\D ]
Feb 17, 2013 | Sony VAIO Computers & Internet
Hi, I have downloaded from DELL website the Dell Dimension 5150 BIOS to upgrade the BIOS. I followed all the steps successfully and restarted the system but it just showed incompatible BIOS on start-up....
first to get a properly bios you need to get the whole description and download it to an floppy disk if it does if not try to boot from a cd...theres a hirens boot cd tools to fix since you already flashed wrong i assume you have some experience use the key tag of yor dell to get properly drivers...
May 27, 2011 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I had tried to flash my Gb-k8vt800m board using @Bios and got a bootblock lock up. I had saved the original bios to a file on my desktop prior. I now have that hard drive as a slave in second identical...
99.9% of all computers will never need the bios flashed.
This is printed on the bottom of the gigabyte web site.
Warning:
Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction.
The problem with your computer has nothing to do with the hard drive. You need to repair the bios. There is a way to flash the bios without booting into Windows. I'm pretty sure that a floppy drive is involved. You're going to have to figure out how to flash it back to your original bios that you have saved on your hard drive without booting into windows. There is some info on gigabyte web site about flashing bios. My internet connection is bad today and I can't download very well from that site or I'd give you an address. www.gigabyte.com.tw
Also remember that when you flash the bios all the settings in your bios reset. You should enter setup and click on the "load optimal defaults" Then you need to make sure date and time are right. Need to set boot options. Check that the clock ratio is right for CPU. There are a lot of options in there that can be keeping your system from booting it isn't necessarily a failed bios flash other than not getting the settings right after flashing.
Nov 25, 2009 | Intel Motherboard
My pc partially doesnt work. when i press the
I would start with a new bios battery first.
There is absolutely no need to reformat a hard drive for a bios issue.
I would also hold off on flashing bios just yet although that could be a later option.
Just take note of the battery position IE positive "+" up or down.
Sep 03, 2009 | ASUS P4PE-X Motherboard
Dead gigbyte GA-81945 Pro ,, Help with compatabilty issues!
Hi bob_snz:
If the bios is corrupted, as it seems to what happened, you may be able to fix it.
So, what you can do to restore this board, if the bios is replaceable is to buy a new bios module for this board. Be sure to get the exact model marked on the board with the version #.
u
The data is still on the hard drive. So, what you can do with the hard drive, if you decide to get a new board instead of trying to fix this one is to put the hard drive in another computer and set the drive as slave. Next is to copy your data to a DVD (s) or another hard drive.
In this case you have a couple possibilities. Try to fix this board with a new bios module (if it is removable).
Unplug your hard drive. Use another computer to download the correct bios flash version. Use a floppy if available, to try to flash the bios again. The floppy would be self boot to access the bios without booting the computer. Usually the floppy only boots what is necessary to get to the bios firmware and loads to the bios flashing it to the correct firmware.
Since the bios may be corrupted, this operation may not work, but may be worth a try. If you do not have a floppy on the computer find a floppy from a friend or if you have one, install it and proceed.
Again, it may not work if the bios is completely out of commission.
Hope it works.
Aug 23, 2009 | Intel Motherboard
BIOS stops booting with two CD checks
1. Chek whether the time and date is correct
2. If No, change BIOS Battery, if Yes, No need to change the Battery
3. Install the latest Version BIOS (if the existing is the L8st, then reinstall)
4. Selct "Load Optimal Default" in BIOS and try to boot
Dec 15, 2008 | E-Machines eMachines Desktop PC
Via epia-5000 motherboard with Award BIOS
Couple of things you have to do...first, flash the bios with EPIA0207.BIN (using awdflash.exe). Likely you're going to have to pull that drive and reformat it, there's a great in-depth tutorial here (includes where to get the files): http://eurowonka.blogspot.com/2009/03/reclaiming-my-mirra.html
I noticed that after flashing the BIOS I had to pull the CMOS battery, move the jumper on J10 to 2-3(check the corresponding manual for your board), let that sit for about 5-10 seconds, move the jumper back to 1-2 on J10, and replace the CMOS battery. As soon as all of that was done...I was in, no password required.
Nov 09, 2008 | VIA Computers & Internet
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
BIOS password.
BIOS password article regarding Toshiba Satellite A135-S4427
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1816197xml&sliceId=&dialogID=32999663&stateId=0%200%2032997592
you actually should be able to "FLASH" your bios through windows.
Direct download page for BIOS
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=1731516xml&sliceId=&dialogID=32999663&stateId=0%200%2032997592
Be sure to take your time to read the instructions and follow them dont have any programs open.
hope that helps!
Jan 29, 2008 | Toshiba Satellite A135-S4427 Notebook
CMOS battery drains after one startup. Gigabyte GA-K8N-SLI
OK lets see here! Make sure your CMOS jumper is set properly on the board(Set to Normal) or Did you configure your bios after flashing the bios(going into bios and Load Optimized Defaults!)? or I don't think it would be another device in the system, but you can try troubleshooting by starting up with only what you need to run the machine (Mobo, memory harddrive, keyboard and mouse) then one by one adding devices back! or Did you have problems like this b4 you flashed the bios! Try flashing the bios back to an older version! post back if anything new or if i'm way off! Good Luck regards, babb
May 03, 2007 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
Biostar NF325-A7 Motherboard Logo
328 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
