Question about Acer Aspire One PC Notebook
Laptop doesnt find connection to cable modem
Hello,I try to connect my laptop to a cable modem Motorola SB5100 with an USB cable. When I plug it in I can only hear characteristic sound but nothing is happening on my laptop and therefore I can't connect and use Internet. DO you know what can be wrong with my laptop? Apparently I don't have to install any drivers as my neighbour is using the same modem and she connected only with a cable and started using internet straight away so that's why I think it's something wrong with my laptop.
  • 1 more comment
  • kasprzakpawe Feb 12, 2009
    jcbag, thanks for your quick help. However I don't think I can use Ethernet. The only space for plug in the modem is for USB cable. all other are used for power cable and other 2 which are disappearing in the hole in the wall so am afraid if I plug them out modem won't be working properly.
    dragonsthatk, am completely cut off the internet so no access=no downloading...:(
    jcbag, I found just now this post so I think even Ethernet cable wouldn't help and my problem is the same as person in this link
    http://www.asksomeone.net/forums/index.p...
    Problem Solver:
  • 17 Answers
Don't Use USB, USB is SLOWER. Use a Ethernet Cable Just like your Neighbor's Computer. FOLLOW THESE STEPS 1 BY 1......Shut Computer Down, Disconnect from Modem, RESET Modem, Wait 2 Minutes, Connect Ethernet Cable From Modem To Computer, Start Computer Back Up & give a minute or 2 for them to communicate.
PS: If your Modem is a New Setup, make sure it's Connected On-Line or Activated through your HighSpeed Internet Service Provider. Most Important, USE ETHERNET CABLE, Not USB.
Posted on Feb 12, 2009
  • 547 Answers
Download setup wizard to find connection from windows
Sb5100 surfboard motorola modem I can't get an Internet connection on my laptop. The only light lit on the modem is standby. I tried unplugging it to reset it but it didn't work. Please help!
the standy by feature is a button on the top of the modem. Press button and check that all your lights come on green (power send recieve and online). then you should have connection
Jan 09, 2011 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need to get wireless on my laptop,
No, the SB5100 is just a cable modem, not a wireless router. You will need to keep your sb5100 but you will need to purchase a wireless router if you want wireless on your laptop. If you can also plug your laptop into the sb5100 via an ethernet cable for your internet connection. Linksys and Belkin and others make wireless routers that you can use for your wireless connections.
May 01, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
I can't install modem drivers for SB 5100 motorola (usb) on my laptop having windows vista. An error is showing that no cable found connecting the modem and computer. Can someone help me how to set this...
Here are the current windows Vista drivers from motorola:
http://broadband.motorola.com/consumers/products/SB5100/downloads/542708-001-install-utility-b.exe
Hope this helps you on your journey
Let me know if you have anything else.
I also would recommend you use ethernet since you do not have to install any software to make it work.
You will need to reboot the cable modem when ever you change how its connected also Ethernet/USB or if it was connected to a different PC.
Please Rate
Jan 20, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Inability to connect to Internet
The easiest solution would be to use an ethernet connection. A second problem is probably on most cable modems you can either use a USB connection OR an ethernet connection you cannoot use both at the same time.
Dec 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Install
If the modem is already registered to your ISP then you can plug the modem to your computer using an Ethernet cable (CAT5) to your computer's ethernet port and to the modem's port as well.
If you want to use the USB cable then you need to install the drivers for it. You may go to motorola website and type in the model number of your modem to get and download the drivers.
Though, I suggest that you use the Ethernet connection instead.
Aug 02, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
System can't Install the MODEM Drivers
You would need to install the USB drivers from the Motorola disk as windows does not have these USB drivers natively.
Jul 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need to hook up Belkin G wireless router to Motorola SB5120
Plug your cable line into your modem, make sure it's tight, but don't use a tool. Next plug the ethernet line from the modem to your PC ethernet port. Then plug in your power to the modem. Allow your modem to sync. Don't use the USB line at all. Do not even hook it up unless your computer doesn't have a working ethernet line. Don't run the disk either, it will only install the modem driver that is only used if you use USB.
If you have issues connecting after that, you may have to go into your ethernet adapter settings and make sure that it is using DHCP. DSL usually uses a different setting (PPP I think) and you will not be able to connect.
By the way, excellent choice in modems.
Jan 14, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Acer Aspire One  PC Notebook Logo
198 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
