Question about Acer Aspire 5100 Notebook
Blue Screen after I put pass word in Its Aspire 5100 I can get to my desktop buy going threw a couple small steps then go from there
  • ashish13
    ashish13 May 11, 2010
    Is it just a plain Blue screen or is it a windows one with some error code on it...
    Problem Solver:
  • 10 Answers
It might be that the hard drive crashed and needs to be formatted. all data on hard drive will be lost and windows will need to be installed again
Posted on Feb 12, 2009
My screen on my toshiba laptop screen is going in and out do I need to buy a new scren/
Most likely your issue is caused by a failing LCD Inverter. You will need to have this replaced. Part is available here: http://cgi.ebay.com/Acer-Aspire-One-A110-A150-LCD-Screen-Inverter-B089AW01_W0QQitemZ190363835846QQcmdZViewItemQQptZUK_Computing_LaptopAccess_RL?hash=item2c52919dc6
This site explains the process for an Aspire 5100 which can also can be used as a reference for your Aspire One model http://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Jan 14, 2010 | Acer Aspire One PC Notebook
After my Acer Aspire 5100 sleeps and the screen does not return
this is a problem with the standby feature there is a patch that Microsoft has put out that should fix the problem i think the main cause is having a usb device plugged in when going to sleep, search Microsoft knowldege base and it should pop right up
Jul 11, 2009 | Acer Aspire 5100 Notebook
Power jack needs replacing aspire 5050 model zr3 laptop
There are TONS of screws in laptops, mainly hidden.  I just took apart a laptop today, and it took me a couple of hours to get the screws out.  There are so many screws!  They are usually under the panels in the back as well.  Here is a link for your computer model Acer Aspire 5100 http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
May 12, 2009 | Acer Aspire 5100 Notebook
NEED INSTRUCTIONS ONHOWWO FORMAT MY ACER ASPIRE 5100 SERIES
hi there
there are couple of steps involved in formating the laptop.
i will try to give simple and easy solution
--> save/backup all your important data into external hard drive or DVD/CD so you will not loose the data
--> i hope you have the xp cd with you
--> put the xp cd in the drive
--> restart the computer
--> press del/f2 to go to BIOS (setup)
--> in boot configure first drive should be your dvd drive
--> press F10/ save changes and exit
--> it will ask press any key to load from cd
--> after that the xp setup will start
--> follow the instructions
--> you can delete and create partitions here too or simply format the drive
--> install the xp
--> install the drivers
--> your laptop is ready to go but dont forget to change the BIOS setting to normal again.
hope it will help you sir.
Mar 25, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5100 Problem
its a fault caused by memory but not because of memory.
Either check ur hard drive with a utility(chkdsk)
or remove hd and clean pins and connection(small shaving brush is ideal for this) replace hd.
It could be bad sectors on drive and if not solved sooner than later ur hd can become damaged beyond repair.
if you have a xp disk,boot up with disk and select "r" for repair then once in dos platform type in " chkdsk" this is the easiest way there are other ways but can cause problems.
Apr 06, 2008 | Acer Aspire 5100 Notebook
Blue screen appers more and more often....
can you adjust buffer size in config please try this
Dec 25, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
