Back to:
Tags:
Paradigm SERVO 15 Speaker
Need advice on speaker configuration.
By Lizzy - usenet poster
I have 3 subwoofers in my system, 2 Paradigm 12 and 1 Paradigm 15" servo
sub, all the subs are ran off the L.F.E. output of my Yamaha RXV-1. A friend
told me it would be better to connect the rear speaker outputs of my
receiver to the speaker level inputs of my sub and then connect the rear
speakers to the output of my sub and then place my 15" sub up front. This
seems logical to me but, wont I be sacrificing sound quality by first using
speaker level input on the sub and then running the rear speakers off the
amp " I would assume the Yamaha is a cleaner power signal. My equipment is:
Yamaha RXV-1
Sony DVP-S7700
Klipch reference speakers, center main, rear
2 Paradigm 12's
Paradigm 15" servo
and a bunch of other equipment irrelevant to the question at hand.
Respectfully
Kevin
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Ranny
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Howard, after reviewing all the advice, I followed yours. You are right the
servo 15 by itself is far more impressive than with the 12's hooked up. Dont
get me wrong though the ps1200 subs are incredible by themselves; but the 15
is in a world of it's own. I guess I'm going to sell my Paradigm PS-1200'S I
have two of them and they are in mint shape.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Need advice on speaker configuration.:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Gary10
Rating: 0%, 0 votes
Hello.
When I recent;y upgraded my sub, I placed my previous PSB Subsonic Sub
in-line with my rear PSB Alphas. Because I have a seperate pre/pro, I
am using line level to and from the SUB and using its crossover to
remove the LF from my Alphas.
...anyway my point is...you would be suprised/amazed with how much
Bass info is being sent to the rear channels. Adding the additional
Ssub to the rear made a huge improvement in my system.
Cheers.
On 16 May 2002 07:58:32 -0700, (Aldo Pignotti)
Thank You!
Solution #3
Not Rated (0)
Perkins
Rating: 0%, 0 votes
Kevin,
I've never heard of using the rears as source for the sub, but why
not the front center channel? I use two 12" JBL subs in my system, one
runs off the standard LFE out, the second is wired to speaker level
connections and uses the front center as its bass source. Even though my
center is quite capable in itself (a Boston VR-12,) the addition of the
sub really works well.
All the best, Mike
Michael S. Davis Creative Media-Works
Computer/Audio/Video Convergence
"from Creative minds spring Creative solutions."
webmas@creativemedia-works.com
Member, International Webmasters Association #
Thank You!
Solution #4
Not Rated (0)
lawyer
Rating: 0%, 0 votes
You have a pretty fine system, particularly that RX-V1, which indeed
has clean-sounding amplification.
Actually, unless you have a huge room the Servo 15 should be able to
handle all the low bass by itself, and do a superior job of it. I
reviewed that sub in issue 71 (Sept/Oct, 1998) of The Sensible Sound,
and it was a subjective match for the Velodyne F1800RII and Hsu
TN1220HO, and would be a subjective match for a pair of Triad Silver
subs that I have recently been working with. It could easily deal with
a room of up to 4,000 cubic feet. You might consider unloading the
other subs, or using them in another system, in another part of your
house.
This is because it is certain that the two smaller subs do not respond
as strongly and uniformly down low (and as clean, either, at least at
high levels), as the Servo 15. So, you might actually be getting
slightly inferior performance by using all three at the same time.
Indeed, you did not mention what kind of hookup you were using from
the RX-V1, but I believe that it has an output impedance with the LFE
hookup of 1200 ohms. That might be rather high to drive three
subwoofer amps wired in parallel.
If you want to stick with all three, anyway, you might consider
keeping the Servo 15 on duty as the main-channel and LFE sub, and then
using one of the smaller subs with the center channel (your RX-V1 has
sub-out/pre-in jacks that would allow for this kind of hookup) and
then using the second small sub with the rear-surround channels, via a
speaker-level hookup. (Speaker-level hookups have only an
inconsequential amount of distortion compared to line-level hookups,
and that would not matter on the surround channels.) Place the units
accordingly, although it would be best to have the rear sub in the
rear, and the center sub up front, along with the Servo 15. You could
put the Servo 15 in one front corner, the center sub in the other
front corner, and the rear sub somewhere near the center rear.
This still probably will not sound much better (or probably any
better) than using a single Servo 15, but it would at least allow you
to use all three subs creatively.
If you want to use the hookup you described, I see no reason why the
speaker-level hookup will be a problem in terms of distortion, but you
still would not gain an advantage over just using the Servo 15 all by
itself.
Howard Ferstler
Author of The Home Theater Companion
(Schirmer Books, 1997)
Thank You!
Solution #5
Not Rated (0)
Horner
Rating: 0%, 0 votes
I've been thinking about doing the same thing with my system but leaving
the sub in the rear. I haven't done it yet mainly because I'm guessing
that there isn't a lot of bass material going to the rear channels.
If I were you, before I fooled around with the rear channels, I would
check out what your woofer sounded like hooked up to the front L&R channels
instead of the LFE channel. It made a big difference on my old reciever
(an NAD716AV). My sub sounded a lot better running off the L&R channels
than the LFE channel. Hooked up to the LFE output, I basically got a
monotone signal. Hooked up to the L&R (front) channels, the sub
produced a sound with much greater bandwidth. I guess the reciever
was doing too much filtering.
Thank You!
Can you Help with these Home Theater Speakers and Subwoofers problems?
my stereo has 1 RCA audio out for the powered subwoofer....
As you can imagine, I've had these speakers for over 30...
my kids were touching the buttons on 1 of the key pads and...
Problem is T6060 comes with the three pin which are...
I only get sound from the Direct and Stereo settings on my...
Loading problems.
Repair Service
Find Home Theater Spe. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
