Question about Stainless Kitchen Ranges
High pitched noise from a smeg SA9066XS dual fuel cooker
I has just had a new cooker installed. It makes a very high pitched nose (not very loud) but very annoying
it seems to come from the front. Its not the timer
alarm.
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
debris caught iside pump assy is what it sounds like
  • 351 Answers
SOURCE: High Pitched Noise
try washing on hottest cycle it may be the seal in the spray pump somethimes the rinse aid can put a glaze on the seal if that doesnt work you can replace just the front part of the motor( in australia) dont know where you are.
Posted on Mar 09, 2008
SOURCE: 1 week after installation- is very loud
dishwasher less then 2 months old was really quiet when we purchased now has a loud vibration noise when water is pumping out.
Posted on Nov 02, 2008
  • 11 Answers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
My 4 door smeg is making loud high pitch shrill noise with quiet knocking coming from the back of the fridge by the compressor and is very hard to listen to what is it?
you just bought it as in new ---get a technician out under warranty---or new to you but second hand ---get a technician out for a proper diagnosis and a quote
May 30, 2016 | Smeg Dishwashers
Looking for a circuit diagram
It's usually und the console. A Google search on how to remove the console for your particular make will give you specific instructions.
Mar 07, 2015 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Cooker makes popping noise when off
It\'s possible you have a slow leak through one of the rail cocks ( gas taps) lift off the top and spray lightly some soapy water on the end of each of the rail cocks if it bubbles you have found the leak.
Apr 13, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster victorians deluxe, double oven , duel fuel
Is there any sort of fan in there - could be some blades hitting surrounding.
Sep 14, 2017 | Rangemaster 110 (Dual Fuel) Dual Fuel...
SMEG A42 fan motor problem
check that the fan mounting screws or bolts are in place and tightened
Aug 02, 2010 | Smeg A42-5 Dual Fuel (Electric and Gas)...
COOKER HOSE
It is illegal to fit a cooker to a gas connection unless you are a registered Gas Safe Engineer . You can find one in your area if you visit www.GasSafeRegister.co.uk
or ring freephone 0800 408 5500
Jun 09, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Feb 23, 2008 | Dishwashers
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Kitchen Ranges Logo
66 people viewed this question
Top Stainless Kitchen Ranges Experts
Craig Butler
Craig Butler
richie46
ray gallant
Are you a Stainless Kitchen Range Expert? Answer questions, earn points and help others
