Question about Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive
Cd/dvd drive does not sense
Suddenly my CD R/W drive is invisible in MY COMUTER.When i open MY COMUTER , CD R/W drive is not aviabe.In DEVICE MANAER thear are TWO YELLOW MARK on CD R/W DRIVER. PLEASE SOLVE THEPROBLEM
    Problem Solver:
  • 5 Answers
1) Is your CD R/W drive disabled in the device manager? If yes, enable it.  OR 2) Update your CD R/W driver using your CD driver
Posted on Feb 12, 2009
    Problem Solver:
  • 12 Answers
Check the bios seting pal, don't use ATA100/133 cable data or set the cable data separated from Hdisk,
Posted on May 10, 2009
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
All of a sudden, my LG GH22LP20 stopped recognizing cd's. I don't have problems with dvd's, they are read and recognized well. I can not burn a cd
thats strange usually if it reads and burns dvd's it should be the same with cd's
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jun 11, 2011 | LG GH22LP20 DVD±RW Burner
My cd/dvd drive has been working fine. All of a sudden when I put in a cd or dvd, nothing opens. the light flashes on the side of the drive and then goes off. I cannot access it from my computer or find...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 22, 2010 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Bios sense cd-rom but not read cd
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Right click my computer and click on device manager then right click on DVD/CD-ROM drive then Scan for hardware changes. Then xp will automatically mount the cd-rom.
May 15, 2010 | Drive Deluxe Fly Weight Aluminum Transport...
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
Same Problem
open the drive and adjust the screw near senser
Aug 11, 2009 | Panasonic Matshita- | CW-8124-B | USB 2.0...
Hi i was installing a game from Cd suddenly there was a noise and cd has broken don't how exactly it happened, then inserted good cd into it but still DVD RW rom is not recognising it in sense not reading...
it really a strange that cd was broken by your DVD rom...... well tell me otherone cd is properly working in your dvdrom.... if yes then may be cd is not read by your drive but if no then sured your cd drive is corrupt...just change it
Mar 31, 2009 | Computers & Internet
How can I tell if my comuter has a DVD/CD drive or just a CD drive?
Normally, the front edge of the Drive tray will indicate CD, CD-RW, DVD or DVD-RW.
You can also check in Device Manager inside Windows (Press the Windows Flag Key+Pause Key, Hardware Tab, Device Manager button) Click the + next to DVD/CD-ROM Drives, and see what model drive is listed. If DVD isn't part of the drive model, it is a CD drive only.
Oct 20, 2008 | Computers & Internet
Compac Presario V2000 DVD CD read problem
ok sir witch company your DVD - RW first telme ?
ok any one open dvd drive clean lenss with cottin net fit same dvd use the dvd & cd data check data cable. open carefully ok you don't know contact H/W Eng : if Any Problam My email id : uday_uday2004@rediffmail.com
Apr 02, 2008 | Computers & Internet
My CD RW/COMBO drive is not visible in My computer
Removing Drive in Device Manager
Remove the drive name from Device Manager:
Select the drive name.
Click the Uninstall or Remove button (in Windows XP this is the square button with a red X, ).
Click Yes or OK to remove the CD listing.
Do not restart the computer.
Close Device Manager .
If your computer has Windows XP, restart computer!
Dec 13, 2007 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive Logo
148 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Brian Sullivan
Brian Sullivan
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
