Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
12 volt battery won't hold charge
12 volt re-chargeable hand drill battery won't hold charge. Can I replace? Where? What price?
2 Suggested Answers
Nic61
  • 1073 Answers
SOURCE: 12 volt re-chargeable battery won't hold charge
Yepp, you can replace it..BUT...its more expensiv to buy a new battery then it is to buy a new hand drill...almost.
If you want to replace it i sugest you go to the store where you bought your hand drill and buy one there.
Good luck to you
Nic
Posted on Feb 12, 2009
Why will my Makita drill not work when the battery is charged?
Could be the the brushes need replaced , how old is the drill
new brushes cost £4.26 inc vat and are simple to fit.
Jul 06, 2014 | Makita 12 Volt Cordless Drill/Driver Kit
The car was running fine one day then the next day it would not start. We tried jumping it thinking the battery might be dead and it still would niot start. The car has power until we take the jumper...
Sounds like you have a toasted battery or alternator. Have you performed a load test on the battery? Have you tried to charge the battery? First remove the battery and charge it externally from the vehicle. If the battery won't hold a charge, or won't hold a charge of 12 volts, replace it. Once you have the vehicle started, test the operation of the alternator. It should be putting out at least 13 volts back to the battery to keep it charged - if it is putting less than 13 volts or more than 16 volts, replace the alternator.
Nov 01, 2011 | 2005 Chevrolet Malibu
How do i take out a skil 12 volt battery drill bit. i havent used the drill in a year or so and i forgot please help, or not
Hi ladogers,
Welcome to fixya!
This drill has a keyless chuck. To remove the bit, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck,
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 16, 2011 | Skil 12 Volt Drill/Driver with Built In...
Milwaukee tool 18 volt nimh battery won!t charge
If the battery pack is more than 2 years old its time for a replacement. The typical charge/discharge life cycle of a rechargeable cell is 500 - 700 times and the shelf life is about 3-4 years from the date of manufacture. If the charging indicator lights up when you dock the battery on to the base and still does not work after 5 hours - its due for a replacement.
Apr 08, 2011 | Dewalt Accessories Batteries 18 Volt
Cordless drill - model KC9682C - probably 8 years old. Stopped working shortly after a battery re-charge. I'm guessing it's the battery. It charges for a few minutes then the red light goes off. Could it...
If light is on charger the charge is fine. You could verify using voltmeter it should put out = to what it says on the back of charger 12-18 volts or so.
Most likely battery is shot after 8 years they just dont' hold a charge anymore and they often will only charge for a few minutes when the chip in the computer tells the charger to shut off due to defective battery.
compare prices of new drills and new batterys sometimes new drill is not much more. Try ebay and harbor freight for ultra low priced batteries.
Mar 03, 2011 | Black & Decker Drills
How long should I charge battery for 12 volt Model
Those batteries should charge up in an hour, some maybe longer, but if takes longer than that, and they still don't charge, they are shot.
Feb 24, 2010 | Drills
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Good luck to you
Nic
Feb 12, 2009 | Ryobi 15" Electric Factory Reconditioned...
Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
97 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
