I am trying to see if anyone knows how to remove the caliper from the break line. It seems that there is a retainer clip. Doesn anyone have any idea how to remove this?
If you refering to the clip that holds the flexible line at a metal mount point where it is screwed in to the steel line. Then you undo the fitting first from the steel line as the rubber hose has flats that prevent it from turning while doing this. Once youhave seperated the lines the clip should have a flat section bent at right angles Grip this with a good pair of multigrips and pull sideways. The clip will come free and the rubber hose will be able to be pulled out of the mount.. Then you unscrew the hose from the calper unit. Best use a new copper washer here to avoid leaks in the future,
SOURCE: need procedure to remove/replace radiator on 01 Dodge Grand Carva
This Link is for R&R rad fan assy, but once your there, the rad should be pretty obvious, what else needs to be done. Fan has to come off first anyway.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528021e5b1
SOURCE: 2005 Dodge Grand Caravan brakes
i dont know if this makes sense, if its the big clip, you push in the cylinder and twist until the clipp comes off
SOURCE: rotor replacement for grand caravan
there is a clip inside the cap, you need to remove the cap. you can use a small screwdriver to pry it up or tap it with a rubber mallet.make sure to reset the bearing after you are done and use alot of grease. tighten the nut and spin the tiretight. then back off to put the pin back... kindly rank me
SOURCE: how to remove fron brake calipers on 1997 dodge grand carivan
That should be all you have to do to remove the caliper. 2 bolts. Sometimes you have to separate the pads from the rotor with a little bar or screwdriver to free up the caliper.
SOURCE: 1995 dodge caravan Break Hangup
this is most likely a fault in the Antilock brake system (ABS) hydraulic controller or a wheel speed sensor, have the system tested for trouble codes.
