Question about Microsoft Computers & Internet
To make computer fast
Make computer faster without changing hardware
    President:
  • 1,901 Answers
The things that I would recommend is that you delete as many programs from your computer as possible. Install an antivirus program that is easy on your memory. Scan your system often and thoroughly for virus/adware/malware. Defragment your hard drive. Run a good Registry cleaner.
If you do that, it's the best you can do without upgrading your hardware.
Posted on Feb 12, 2009
How do I work my Motorola Hitachi DV-P315 features without a remote?
Play / Pause is on the left (in your picture).
Stop is next to it,
Then Fast Reverse (hit more than once for even faster reverse)
Then Fast Forward (hit more than once for even faster forward)
Feb 26, 2015 | Hitachi Televison & Video
1999 bmw 318i clutch or gearbox? (manual)
I would change the viscosity of the oil in the gear box first as if the oil is too heavy the syncro springs cannot handle a quick shift. next check the drain plug magnet for metal bits Lastly check that the clutch operation is spot on and that the clutch is fully disengaging to allow for the fast shift. May mean that you have to put your foot fully to the floor for your fast shifts and not as you see it in the movies. At this stage with you information if the box shifts well under normal conditions then I would tend to discount a faulty box
Feb 21, 2014 | 1999 BMW 3 Series
Firefox slow loading
down load the latest version or update your version
slow loading can be from your modem speed , excessive memory usage or failing hard drive
Jan 09, 2014 | Facebook Social Network
How can i make my computer faster???? What should i change motherboard or CPU and the graphic is onboard. Does it mean if i change motherboard then i have to change Graphic Card???
The biggest impact on the speed have adding more RAM and replacing the CPU. Motherboard is replaced when there is no possibility to upgrade CPU and RAM. The onboard graphic also is not very fast but this is seen in games only. For everyday work any video is OK. If the computer is very slow this may be result of viruses, other unnecessary software and even antivirus software. If you replace the motherboard with a one without internal graphic, you will have to buy also a graphic card.
Apr 08, 2012 | Computers & Internet
Delay when using keyboard
is this a wireless keyboard? if it is that means your sensor that is connected to your computer is not close enough to recieve the signal, if this is not the case your settings for your keyboard could need changing. To do this go Start - Control Panel - Printers and Other Hardware - Keyboard - (first tab will say speed) the marker should be at the third line. This is how fast the computer repeats the character to you when you type. If you want it faster you can set it all the way. Hope this helps. Cheers.
Oct 04, 2009 | Acer NSK8458AN Keyboard
I wana make my laptop blazing fast...i have 1gb ram...and 2 ghz procesor....but it still aint that fast enough.... as i click on the programs button in start menu...it takes much time to show the...
Without changing any hardware there is not much you can do. Just do defrag, and set as many applications as you can to not start automatically.
The point is that 1 GB RAM will make any computer slow, unless you use Linux.
Add more RAM, 1 GB will be barely enough to run Vista at dead turtle speed. Upgrade RAM to maximum supported size, if possible 4GB. You will see the difference.
Sep 16, 2009 | Computers & Internet
How to reduce rendering time in adobe premiere 6.5
Rendering time is controlled by the speed of your computer, both the cpu and the amount of available memory. The faster the pc, the faster it will render. It is also controlled by how large the file is you are trying to render. It is not a setting you can adjust from within primiere.
Sep 15, 2009 | Computers & Internet
Failure to communicate with scanner (Primefilm 1800u)
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this article can helps you to make your computer faster..
Aug 27, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
Tower fan runs fast without stopping
either your computer is running too hot (clean it out physically, or clean out viruses) OR the fan is failing, and it sounds louder and faster cause the bad fan bearings are making that noise.
Mar 12, 2009 | Computers & Internet
Problem in scanned images uploading
If you have 50 units of computer working the same time such as uploading big files, the problem for the rest among your 7 computers that work fast is between the hub connectors on the network system. You can check this connectors by replacing those slow ones to that faster computers.
Then if your faster computers slow down and the replaced connectors from slow working bacomes fast then the problem is in your hub distribution connectors.
If you had trace to that problem, then replace the whole unit of hub connectors.
Aug 08, 2008 | Microsoft Windows XP Professional With...
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
