on some devices it works, wi-fi doesn't turn off in suspend, but on Acer, HP pocket PC's it does.
Perhaps it is some othet implementation for that devices.
Thx...
Was this helpful?
Yes
No
Solution #2
posted on Aug 01, 2007
Bouncy - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
You can try to implement what media players do, prevent the device from sleeping, then only shut the display off. p.s. Only Wifi is shut off on sleep, GPRS connection and non-file transfer bluetooth connections are kept on.
Was this helpful?
Yes
No
Solution #3
Ross - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
You likely can't. When you suspend, the radio is turned off. The OEM made that decision. The only way around it would be to never put the device into suspend mode. You might be able to hack something together that tries to emulate a timeout and then turns off just the backlight, but I'm not sure how you'd get it all working without being directly in the PM, battery and touch driver pipelines.
Chris Tacke, Embedded MVP OpenNETCF Consulting Managed Code in an Embedded World #
What settings do I have to enter into the N300 to connect to the internet through my home wifi...
(More)
What settings do I have to enter into the N300 to connect to the internet through my home wifi system. I have a WLAN SD card.
acer n300 turn off if remove from power ( charging ) i don't know its'"s battry problem or...
(More)
acer n300 turn off if remove from power ( charging ) i don't know its'"s battry problem or something else.
I guess the joystick of my n300 is having problems, Is there a way to cancel it using a trick in the...
(More)
I guess the joystick of my n300 is having problems, Is there a way to cancel it using a trick in the software?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
