Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint aquarius wma50
How do i adjust the motor to replace the belt and brushes i carnt get to the left brush out
  • 1 more comment
  • susan starbuck
    susan starbuck Feb 12, 2009
    how do i get the brushes out of a hotpoint aquarius 1000
  • susan starbuck
    where abouts is the motor lead iv undone the motor on a hotpoint washer
  • susan starbuck
    whats the easist way to put the belt back on it wont go back on
  • Hotpoint Master
  • 3,463 Answers
The motor does not have provision for belt adjostment, it is self tensioning
To gain access to the brushes, you need to remove the motor from the washer.
Remove rear panel, remove belt, unplug motor lead, taking note which way the plug goes,undo screws securing motor, and lever motor back with a screw driver, remove motor and change brushes.
Posted on Feb 12, 2009
  • Barry Coates
    Barry Coates Feb 12, 2009
    It is a white plug with several wires going into it, it may be at the rear of the motor, or at the front, it all depends which motor is fitted to the washer.
    Hope this helps.
Our hotpoint WMA50 is draining but the drum is not turning
Can you hear the motor running if you can all that is needed is a new belt. But if you can not hear the motor running then the motors carbon brushes need replacing. http://www.youtube.com/watch?v=HELgV4KOsT0&feature=channel this shows the carbon brushes on a hotpoint. http://www.youtube.com/watch?v=X1yY_6vKK8g&feature=channel This shows how to change belt. hope this helped.
Dec 28, 2010 | Hotpoint Washing Machines
Motor brushes....how do you change them
Remoe lower rear cover of washer.
Remove earth wire, and unplug motor socket.
Remove belt and remove 2 bolts securing moor. holding moior, lever motor towards rear, and remove motor from washer.
Change the brushes in the motor.
Oct 08, 2010 | Hotpoint WMA50 Front Load Washer
Wer is the brushes in a hotpoint aquarius extra as it wont go in2 a spin
YOU WILL NEED TO REMOVE THE MOTOR FIRST TO SEE IF THE BRUSHES CAN BE REPLACED AS SOME OF THE MOTORS FITTED WERE SEALED UNITS. 15 MINUTES TO REMOVE THE MOTOR. BRUSHES ONLY ABOUT £25
Jun 22, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a Maytag Atlantis MAVT754EWW machine and there is a black soot like substance being left on the floor under the washer. It smells like rubber - do I need to replace the belt and if so, how do I do...
this black soot like substance is the motor carbon brush dust. i would get the motor brushes replaced and clean off all the dust from the pulleys and also replace the belt as it has been slipping on the dust.
Mar 18, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Aquarus 1200 hotpoint motor not working
Check the motor brushes for wear.
Replacement carbon mototr brushes available at :
www.hotpointspares2u.co.uk
Regards
Steve - SDA Ltd
Aug 10, 2008 | Hotpoint Aquarius WD63 Front Load...
You should be able to do both without disturbing the motor.
To do the brushes - about half an hour...
1. UNPLUG the washer.
2. check you've unplugged.
3. Tip the machine carefully up so you can get to the underside
4. Pull cables off the existing brushes.
5. Remove the brushes with a cross head screwdriver. Each brush as two screws holding in on, but the brushes are keyed into the motor chassis. They are fiddly.
To do the belt. + as long as your patience lasts...
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic cap on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel. To pop the belt off, turn the wheel forcing the belt to the edge of the wheel. It will eventually come off.
6. to replace belt - see motor shaft at bottom of unit. Dangle belt round shaft of motor and gently pull so it does not come off.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
Mar 13, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Feb 19, 2008 | Hotpoint WMA50 Front Load Washer
Washing Machine 1200 Aquarius- Hot point- will not spin?
hotpoint use two types of brush depending on the motor. if motor mounted at top of machine, brushesw are clip in and very easy to replace. look at new brush and you will see how it clips in. no need to remove motor. if motor at base of machine, brushes are screwed in with two screws per brush. rather fiddly to do in situ and you may be better of removing motor and doing job in an easy position
Apr 27, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
379 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
