Question about Microsoft Windows Vista Ultimate Edition
Need file path for os activation
I need the windows file path in os directory for checking the activation of windows os
    Scholar:
  • 75 Answers
To check the Vista activation status is easy. Users can simply right click on “Computer” on “Start Menu”, and then click on “Properties” on the right click context menu. On “View basic information about your computer” page, scroll down to bottom, and Windows activation status is listed under “Windows activation” status.
Another way is open up the Command prompt {Start > Run > CMD} & then type in slmgr -xpr and then hit Enter.
Hope this solves your query :-)
Posted on Feb 12, 2009
  • ashish13
    ashish13 Feb 12, 2009
    Computer> C:/Windows/System32/slmgr.vbs
Where i can get software for C Programing language and what is the software name...........?
STEP 1 : Download the Borland Compiler
https://downloads.embarcadero.com/item/24778
STEP2 : Run the setup program
By default, it should install everything to C:\Borland\BCC55
STEP 3 : Add the /bin directory to the system PATH
>C:\Borland\BCC55\bin\bcc32 OR >c32
After the setup program is run (step 2), a whole bunch of executable programs are placed in a new directory : C:\Borland\BCC55\Bin. This step makes it possible for the Operating System (Windows) to find these new executables by name. If you don't do this, then you will need to specify the full path to bcc32 every time you use it.
To do this on Windows XP
Bring up the Environmental Variables :
•Right Click "My Computer" ( Depending on how your system is set-up, "My Computer" is either on your Desktop or in your Start Menu )
•Select "Properties"
•Activate the "Advanced" Tab
•Click the "Environmental Variables" Button
Append ";C:\Borland\BCC44\bin" to the PATH variable (figure 3-2)
•Select the PATH variable under User Variables
Note: The PATH variable may appear under both System Variables and User Variables. This How-To changes the User Variable.
•Click the EDIT button below the list
•In the "Edit User Variable" box that pops up, move the cursor to the end of the Variable Value field
•Add a semi-colon ";" to the end of the current value
Note: If the value is empty, then you do not need to add a semi-colon
•Add the path "C:\Borland\BCC55\bin" after the semi-colon
•"OK" your way out of the dialogs
STEP 4 : Set up some configuration files
you should create a configuration file for the bcc32 program that tells it where to find its libraries and include files.
•The file should be named bcc32.cfg
•It should be placed in the same bin directory where bcc32.exe is located
(C:\Borland\BCC55\Bin)
•The contents of the file are the command line options for bcc32 stating the location of include files and libraries:
-I"C:\Borland\BCC55\Include"
-L"C:\Borland\BCC55\Lib"
Regards,
Soul_srch007
Dec 06, 2009 | Microsoft Windows XP Professional
Cannot Open DSA.MSC file error
When you install the Administration Tools Pack on a computer that is running Windows XP Professional x64 Edition, the Active Directory Users and Computers MMC snap-in file (Dsa.msc) is installed in the %windir%\Syswow64 folder. Additionally, the computer's file system maps the Active Directory Users and Computers MMC snap-in to the following path: DriveLetter:\%windir%\Syswow64\Dsa.mscHowever, the Active Directory Domains and Trust MMC snap-in incorrectly specifies the path of the Active Directory Users and Computers MMC snap-in as follows: DriveLetter:\%windir%\System32\Dsa.mscWhen the computer's file system tries to locate the Dsa.msc file from within the Active Directory Domains and Trust MMC snap-in, Mmc.exe is run. Mmc.exe is run because the Dsa.msc file is associated with Mmc.exe. When Mmc.exe is run, it uses the following path to locate Dsa.msc: DriveLetter:\%windir%\System32\Dsa.msc DomainPathAfter the Mmc.exe command is run, the Active Directory Domains and Trust MMC snap-in tries to locate the Dsa.msc file. Because the Dsa.msc file does not exist in the %windir%\System32 folder, the error message that is mentioned in the "Symptoms" section is generated.
To resolve this problem, manually copy the Dsa.msc file from the %windir%\Syswow64 folder to the %windir%\System32 folder.
Your hardware manufacturer provides technical support and assistance for Microsoft Windows x64 editions. Your hardware manufacturer provides support because a Windows x64 edition was included with your hardware. Your hardware manufacturer might have customized the Windows x64 edition installation with unique components. Unique components might include specific device drivers or might include optional settings to maximize the performance of the hardware. Microsoft will provide reasonable-effort assistance if you need technical help with your Windows x64 edition. However, you might have to contact your manufacturer directly. Your manufacturer is best qualified to support the software that your manufacturer installed on the hardware.
For product information about Microsoft Windows XP Professional x64 Edition, visit the following Microsoft Web site:
http://www.microsoft.com/windowsxp/64bit/default.mspx (http://www.microsoft.com/windowsxp/64bit/default.mspx) For product information about Microsoft Windows Server 2003 x64 editions, visit the following Microsoft Web site:http://www.microsoft.com/windowsserver2003/64bit/x64/editions.mspx
May 30, 2009 | Microsoft Windows Server Standard 2003 for...
File path trouble
what happens when you cancel through the file needed error....? it looks like setup is looking for USB drivers...you should be able to cancel the install of those drivers and add them later when windows is up and running.....failing that t looks like the drivers it is searching for are in the i386 directory....so instead of copying file from "globalroot\device\etc\etc you should point the path to the i386 directory on the repair disk....possibly D:\i386\
Dec 30, 2008 | HP Compaq Presario V2000 Notebook
Installation path change
Change The Default Location For Installing Apps -----------------------------------------------
As the size of hard drives increase, more people are using partitions to separate and store groups of files.
XP uses the C:\Program Files directory as the default base directory into which new programs are installed. However, you can change the default installation drive and/ or directory by using a Registry hack.
Go to :-
- Start > Run
- Type “regedit” (without “” NOOBS!)
- Go to this directory… HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
- Look for the value named ProgramFilesDir. by default,this value will be C:\Program Files. Edit the value to any valid drive or folder and XP will use that new location as the default installation directory for new programs.
Oct 19, 2008 | Computers & Internet
Turbo c++ programming is not working
If turbo c++ is placed in any other drive than c drive then u hv to provide correct path by going through Option >>directories>>Library Directories and provide exact path where ur turbo c++ is placed.
Oct 06, 2008 | Microsoft Windows XP Professional With...
Microsoft Outlook 2003 sycn with yahoo email
Windows 95, 98, and ME syntax
Deletes one or more files.
DEL [drive:][path]filename [/P]
ERASE [drive:][path]filename [/P]
[drive:][path]filenameSpecifies the file(s) to delete. Specify multiple files by using wildcards./PPrompts for confirmation before deleting each file.Windows 2000 and Windows XP syntax
DEL [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
ERASE [/P] [/F] [/S] [/Q] [/A[[:]attributes]] names
namesSpecifies a list of one or more files or directories. Wildcards may be used to delete multiple files. If a directory is specified, all files within the directory will be deleted./PPrompts for confirmation before deleting each file./FForce deleting of read-only files./SDelete specified files from all subdirectories./QQuiet mode, do not ask if ok to delete on global wildcard/ASelects files to delete based on attributesattributesR Read-only files S System filesH Hidden files A Files ready for archiving- Prefix meaning notIf Command Extensions are enabled DEL and ERASE change as follows:
The display semantics of the /S switch are reversed in that it shows you only the files that are deleted, not the ones it could not find.
Windows 2000 and Windows XP recovery console syntax
Deletes one file.
del [drive:][path]filename
delete [drive:][path]filename
[drive:][path]filenameSpecifies the file to delete.
Delete only operates within the system directories of the current Windows installation, removable media, the root directory of any hard disk partition, or the local installation sources.
Del and delete do not support replaceable parameters (wild cards).
Examples
Notice: Users who are running Microsoft Windows 95 and are used to deleted items going to the recycle bin need to keep in mind that deleting files from MS-DOS does not send files to the recycle bin. del test.tmp = Deletes the test.tmp in the directory that you currently are in, if the file exists.
del c:windows est.tmp = Delete the c:windows est.tmp in the windows directory if it exists.
del c:windows emp*.* = (* is for wild character(s)) *.* indicates that you would like to delete all files in the c:windows emp directory.
del c:windows emp?est.tmp = (? is a single wild character for one letter) This command would delete any file ending with est.tmp such as pest.tmp or zest.tmp...
You may also configure your outlook express to auto delete Emails by creating a rule for them.
Illustration.
If you can not see the illustrations properly , youtube has excellent tutorials.
http://www.youtube.com/watch?v=wcb7x7ErtO4
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Microsoft Office Outlook 2003 for PC
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
mode.
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
CD burning
Is the Temporary file full with .tmp files? If so Windows can not accept the files from the Burner. Also make sure in your Burner Options that you have Checked the Option to Write Files to the Windows Tmp Directory, also check the file path and make sure that is is directing the burner files to the correct area.
May 10, 2008 | Computers & Internet
Code error 0x80040606
Can you try the following to see if it works? 1st, Make sure QuickCam Version 11.0.0.1218 is installed. 2nd, Make a copy of the "C:\Program Files\Common Files\LogiShrd" to "C:\Program Files\Common Files\Logitech". After you make a copy of this folder, under C:\Program Files\Common Files you should see both a "LogiShrd" and a "Logitech" folder. Both folders should have the same content under them (ie. "LVMVFM" directory, "KAudP" directory, etc...) 3rd, Uninstall Logitech QuickCam Version 11.0.0.1218, and the QuickCam Drivers in Add/Remove programs. 4th, Reboot. 5th, Reinstall 11.0.0.1218 See if this works... Also, an alternative: instead of "uninstalling" Logitech QuickCam version 11.0.0.1218 in Step 3 above, you can try "Repairing" it from Add/Remove, and do not uninstall the drivers. Background: Working with a forum poster, we found a problem with a path-resolution function that maybe triggered by a Windows Update. Basically, it seems a Windows Update is added some extra folder attributes that causes the path resolution function to fail. When the path resolution failed, the code was set to failsafe to a "Logitech" directory instead of "LogiShrd" directory. This would also explain why these problems don't happen 100% of the time (because it seems the path resolution function doesn't fail 100% of the time) and the errors started appearing in 10.5 and above, when the Logitech folder was renamed to LogiShrd. Hope this helps!
Apr 07, 2008 | Logitech QuickCam Pro 5000 Webcam
Mar 12, 2008 | Logitech QuickCam Pro 5000 Webcam
Microsoft Windows Vista Ultimate Edition Logo
69 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
