Question about ASUS VW202T 20 inch LCD Monitor
Front panel controls
The handbook does not say what the front panel controls do or how to change them. I have found out a few things by trial and error but is ther a more detailed instruction book for the vw202s ?
  • mmrw Feb 12, 2009
    That was very helpful thanks, but should there have been a CD in the box. All I got was a Quick start guide. Are there any drivers needed?
    Regards
    Mike Williams
  • mmrw Feb 12, 2009
    excellent
    President:
  • 1,901 Answers
Not sure how detailed you need, but here is the user guide from Asus:
Asus VW202 User Guide
Overview is on Page 1-2.
More detailed instructions begin on Page 3-1.
Posted on Feb 12, 2009
  • Wayne Mineard
    Wayne Mineard Feb 12, 2009
    Yes, there is a driver. Go to Asus Download Support
    In the upper left corner, type in vw202s in the "Input Model To Search" block.
    Click on the Search Info button.
    Three models should come up. Click on your VW202S.
    You will then get a Select Operating System window. Select yours from the drop down menu. Click on Search.
    You will then get a list of available downloads. The driver is listed under "Others".
    Click on the + next to "Others". Click on "Global".
    The download window will open. Select Save and save it to your desktop.
    When the download is complete, close the window. (If it did not automatically.) Close all other programs, and run (double-click) the file on your desktop. This is a zip file.
    I'm not sure if this will install from there or if you will have to go to the .exe file in the folder that the zip file extracts to.
    If you are satisfied with this additional info, consider increasing the rating to "Fixya". Thanks!
  • Wayne Mineard
    Thanks Mike.
How do you get the front panel off a fisher paykel dryer to replace the felt seal
my F&P front load dryer would not start - it would hum when I pushed the start button. After trial and error taking the top off, then the front panel with the door I found the lint exhaust was completely blocked. After doing a thorough cleaning of the dryer and putting it back together it worked! (note: DE60 Elba dryer)
Jul 14, 2014 | Fisher and Paykel DE09 Dryer
Frigidaire front load dryer Model # LEQ2152EEO runs only on low. When on any other settiing I get ther DR error message or it will run for 2 minutes and then stop. Any idea what this could be?
DR is door error
this generation of dryer has allot of control board failures(the relay for the heat burns the terminals for the wires)
you can inspect these relay connection visibly by removing the front control panel. If those look good, you will need to replace the control board. Here is the control board to order.
Nov 05, 2012 | Washing Machines
My refrigerator keeps beeping as if I left a door open. on the panel it says "dispensor and button" 3 secs Things in the freezer are starting to thaw out.
http://us.lge.com/download/product/file/1000000180/LRSC26980owners.pdf
I looked and looked in the manuals and the only thing that I found for dispensor and button was the lock and unlock of the dispensor - if you hold the lock button down for 3 secs it will either lock or unlock the buttons. So you need to check to see whether the controls are locked or not. If they are then unlock and set the temperature for the refrigerator and freezer on your control panel.
http://www.ajmadison.com/ajmadison/itemdocs/8645A_Eng.pdf
I don't understand why your food is thawing unless there was a power surge that changed all your settings.
If this isn't the problem, let me know and I will look further. Troubleshooting a problem without being able to see what the indications are, is something that takes a lot of trial and error.
Jun 10, 2011 | LG LRSC26980 Refrigerator
My sync button crapped out so if anyone has this problem if you open the controller removing only the front cover and hold the sync button then make contact with the first and third contacts to each other...
Thanks for sharing this. All the buttons have a metal disc under the rubber sheath. So if you make contact with a metal circular button to the board it also works.
Feb 22, 2011 | Microsoft Xbox 360 Controller
Front load he3 kenmore, control panel had an F now is locked up! Have unplugged for 30 min. no change
I just experienced a similar problem, getting an F21 error and 5d.
F21 error was a clogged drain. Unplug firest, then remove the lower front panel (it may be from the back panel) and look for a drain valve. unscrew and clean out good. I found approx $6 in change, keys, bobby pins, hair clips, etc. then put all back together and run a cycle empty. Save myself $250 I dont have and did it myself. This website is wonderful.
Denise
Dec 17, 2010 | Kenmore Front Load Washer
WHAT DOES ERROR CODE F20 MEAN? JUST MOVED & HANDBOOK CANNOT BE FOUND RIGHT NOW.
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. The following link explains some of the common causes of the error code and how to troubleshoot: http://www.fixya.com/support/r3608632-f20_error_code The error codes aren't listed in the owner's manual.
Each one of these washers come with a technical data sheet inside. To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information and let me know if you need assistance beyond what the tech sheet provides. I hope you find this information helpful.
May 11, 2010 | Kenmore Elite 45986 Front Load Washer
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Mar 23, 2009 | Brother HL 1250 Laser Printer
Hitachi SP-43W magic focus
remove front grill assy to front of the internal pc boards.on your left side ther is a blue rest button mounted on the convergence board this is the eprom rest ,unless yuo know and have the service manual do not rest the eprom at this time. look at your front control panel to see if thers a small hloe and if so you need a thin rod to acitvate the button inside. again the service book will help /
Aug 22, 2007 | Hitachi 43F300 43" Rear Projection...
ASUS VW202T  20 inch LCD Monitor Logo
431 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
