Evaporative air conditioner not working
I have a Brivis contour ducted evaporative air conditioner model L41. The problem I have is the solenoid won't let water through into the system, I have changed the solenoid twice and each time when I start the unit it will run for a couple of seconds then trip the circuit breaker and shut down the entire system. I then reset the circuit breaker and try to restart the unit but then the solenoid wont let any water into the system at all.
Any ideas.
  • lblund Feb 14, 2009
    There is one exteral valve which connects to the solenoid via a braided stainless tube. this is not blocked
  • Pyldrvr May 11, 2010
    Are there any in line water valves that may be closed manually of electronically.
  • 56 Answers
Wish there was more that I could do to help but you may need to have someone or yourself check for anything shorted/grounded and also make sure the voltage is correct to the solenoid.
Posted on Feb 14, 2009
Sweating duct work and pipes
high humidity will cause sweating on cold lineset and ductwork,,, insulate both and it will solve problem
Jun 03, 2014 | Ruud Central System Air Conditioner
Brivis evaporative cooling
you have an reset on the contoller,try it.
Dec 05, 2013 | Heating & Cooling
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Last night my Brivis evaporative cooler didn't seem to be working very well. I left it on low overnight and when I got up this morning, the system is no longer working and there is no display on the...
Yes the evap coolers do need maintenance just like all other air conditioners,
The end result of controller no longer working is indicating there is now a electrical issue.
You should contact a Air Conditioning mechanic for a breakdown.
Jan 25, 2011 | Heating & Cooling
Our brivis evaporative cooler won't start.The on/off switch only gives a beep but the screen is blank.
could be the control box in the unit. could be a faulty controller. most likely to be a damaged lead. mice like to eat them. It may have a very small amount of damage.
Jan 08, 2011 | Mastercool 67471 Evaporative Cooler Air...
Our fan on our brivis evaporative cooler is not working. The pump to fill it with water is working and the fuse is fine. what else could it be - the unit is on the roof and I can not get to it.
there is a fan insert with a part Number 17517 this insert sits on the shaft of the motor. my fan is working but not blowing so i went up on to my roof and found out that this particular insert is broken (due to a birds nest )
May 17, 2010 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
We have a brivis ducted evaporative cooling system and i was wondering how long we can safey run it continuosly?
When you say safely, do you mean operating it with the required doors and windows open? You can run it 24/7 as long as it is operating according to the owner manual.
Jan 30, 2009 | Maytag M6Y18F7A Air Conditioner
Brivis Ducted Heating system. No display on Programmable controller inside hoiuse. Electronic Control (Model 14100) located on Heater (outside house)displays "Searching". Have turned off...
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Jun 10, 2008 | Heating & Cooling
Heating & Cooling Logo
394 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
