Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Pc fax transmission problem for bizhub 750?
I purchased a new machine that is bizhub 750 now problem is that i did'nt got additional fax kit? while asking supplier, i was told that fax kit is optional. now i just want to send fax through my machine to another fax through pc-FAX. now my question is that is there any utility or software that i can send fax through my machine or computer to another fax.
  • 167 Answers
The only solution may be a very expensive "Fax server".
You must have the fax kit in order to translate your print file to the fax language.
Is like trying to send an email without a modem, you may have access to a network but cannot talk the language required.
Posted on Feb 17, 2009
Has anyone had scuming on back side of sheet only. if so what was the fix.
Sir/Mam,
Yes you mite need to have the upper and lower fuser rollers replaced. When was the last time a Preventive Maintenance (PM) Kit 250K was done. every 250K copies the machine needs a PM and the developer needs replacement. The drum is replaced every 500k. Is there a tiny wrench being displayed in the upper right of the op screen? If so PM required.
Dec 31, 2014 | Konica Minolta Bizhub 600 750 Image...
Konica minolta bizhub 600 not automatic toner feeding how can resetting
1. Remove the toner bottle then turn on the machine with out bottle inside of it. Let it go though its normal operations then when the machine asks for toner install the bottle.
Dec 18, 2014 | Konica Minolta Bizhub 600 750 Image...
How to reset a password of bizhub 600-750
Which password the admin or the individual passwords Default admin 12345678 or 00000000
Go to:
Admin setting- Security setting -admin password
Oct 23, 2014 | Konica Minolta Bizhub 600 750 Image...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
Bizhub 600 reads wrong paper size in tray 1
Is tray 2 OK?
Any paper stuck behind the draw. Check the setting off draw one in user mode is it for that size paper?
Apr 23, 2013 | Konica Minolta Bizhub 600 750 Image...
My konica minolta bizhub 750 show me 5003 error. please can someone tell me what it means and solutions. thanks
Printer Control Board fault. Recommend first checking all connectors pull each one out then reseat them, as you do that check each connector on the board for a bent pin, if not have bad image control board $$$$$$
Apr 02, 2013 | Konica Minolta Bizhub 600 750 Image...
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Konica Minolta bizhub 200 Printer
Sharp AR 168s cant fax
If the fax kit is installed you will see the phone ports on the back. If no ports then you don't have the fax kit. It was not standard in the 168s
Jan 23, 2009 | Sharp AR-168D Copier
Konika minolta bizhub 350 fax no answer
Try altering the maximum nuber of rings until it relays the no answer message.
I am not sure exactly where that is.
ALso, you could try turing on the phone line volume so you can listen to what is heppening.
Sep 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
307 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
