Question about Frigidaire ATF6000ES Front Load Washer
Washer empties afterwash cycle but doesn't empty during the rinse
Cycle. the timer keeps moving you can hear clicking during the drain cycle but the water never drains. the tub does keep moving forward then stops then backwards then stops. just doesn't drain. and it doesn't dump the fabric softern.
    Sergeant:
  • 197 Answers
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 01, 2009
  • Evan Benson
    Evan Benson May 01, 2009
    set to go.
Maytag washer (LAT7400AAV)shuts off during rinse cycle
The machine control board is programmed to allow a maximum continous fill time of six minutes
or an accumulated fill time of 8 minutes for each full wash cycle.
If the required fill time exceeds the time limit, the washer will shut down.
This is to prevent flooding in the event there is a loose hose clamp or damaged air dome hose.
Check the incoming water lines for a minimum pressure of 20 psi.
If lower, the customer can use smaller clothes loads and reduce the pressure to 10 psi.
An alternative solution would be to change the plastic inlet screens to metal screened washers
and remove the nozzle extender found in the water valve inlet hose near the dispener inlet."
Dec 10, 2014 | Maytag Washing Machines
The water will not empty. It just sits there
Most likely the pump is bad or the timer is not deliver the signal. If you can drain manually that mean the pump is good, but only the timer controller. If you can't drain manually, then either the pump is bad or the electrical path to the pump has been broken. Try to unplug power for a while to reset then re-start with the rinse cycle only. Good luck.
Jan 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Will not empty at rinse cycle
Check your lid switch.Make sure that when the lid is lowered you can hear the switch click.
Jun 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machine won't empty water during the cycle
does the timer advance by itself? if not the problem is your timer not advancing through the cycles. if timer does advance then being 14 1/2 years old it could be the motor. start the washer and mark the beggining where the timer starts. whatch it to see if it moves if not then you need to replace your timer
Jan 30, 2007 | Whirlpool LSR9434PT Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
prem mathew
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
