Question about HP Compaq FS7600 17" CRT Monitor
MY COMPUTER BOOTS UP W/BIOS INFO(KEYBOARD,SPEAKERS)
THEN IT GOES TO "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. I TRIED PRESSING F8,& F10 KEYS TO RE-BOOT IT. DOES NOT WORK AT ALL. GOES RIGHT BACK TO THE SAME SCREEN. WHAT IF I DON'T HAVE THIS DISK. WHAT SHALL I DO TO FIX IT. THIS IS A COMPUTER I BOUGHT FOR MY KIDS IN OCT 2005 TO DO HOME WORK. SOMEONE REPLY BACK WITH HELP.
  • 32 Answers
I do not know if you can do this, You should open you CPU and Unplug the cable to your HardDisk and plug it again after one - two minutes.
Posted on Feb 12, 2009
How do get into bios on compaq 6200 pro
On start up, press F8 continuously, will take you to bios.
Feb 02, 2015 | Compaq Computers & Internet
HAVE REALTEK RTL8101E/8102E ETHERNET CONTROLLER PXE-E61 MEDIA TEST FAILURE CHECK CABLE PXE-MOF EXITING PXE ROM LOOP. HAVE TRIED ADVANCED BOOT . CAN I USE RECOVERY DISK INSTEAD OF VISTA DVD WHICH I DO NOT...
It is important to isolate the cause of the "PXE-E61 Media Test Failure, Check Cable" error and solve it. To do this, follow the steps below:
  1. A loose or improper hard disk cable connection can be the cause of the error. This typically happens if the hard disk has recently been installed or moved. Check all of the hard disk's cable connections before trying anything else to solve the error.
  2. Make sure that no other storage device is connected to the computer. If there is a storage device connected, remove it.
  3. When computer start up is being attempted, enter the BIOS to see if the hard disk has been set up correctly and detected in BIOS. To enter the BIOS, follow these steps:
a. The key that must be pressed to enter the BIOS varies depending on the computer model. The key is most likely the Del key or one of the F keys. Many computers refer to this as Entering Setup and Setup is just another term used for the BIOS.
b. Try setting one's BIOS to any safe default settings. That might fix the error.
  1. Verify that the boot options in CMOS are setup correctly. Follow these steps to do this:
a. Enter the CMOS by pressing one of the following keys: F1, F2, Del, Esc, or F10. Press one of these keys when trying to start up the computer. If these keys do not work, try holding one or more keys on the keyboard when the computer is booting. This may cause a Stuck Key Error, which should allow the user to enter the setup.
b. If the CMOS setup shows an option to boot from the LAN, disable this option.
c. Try to set the CMOS settings to any safe default settings, then save and exit. After changing any settings, reboot the computer.
  1. It is possible that physical failure caused the error if the hard disk cannot be detected. If this is the case, replace the hard disk and restore one's data if a good backup is available. If one does not have a good backup, contact a company that provides data recovery services. These companies perform hard disk recovery and securely retrieve one's valuable data.
Check that the drive is detected in BIOS:
  1. Press F2 during boot to enter BIOS Setup.
  2. Go to the Boot menu.
  3. Check the Boot Drive Order.
  4. Press F10 to exit BIOS Setup.
If Boot Drive Order shows No Boot Drive:
  • Check that the drive is properly installed in the computer.
  • Try installing a different known good drive.
If PXE Boot is enabled in BIOSTo check the BIOS option:
  2. Go to the Boot menu and check for Boot to Network.
  3. Press F10 to exit BIOS Setup.
If you do not plan to boot to a network, disable this option.
If you do want to boot to a network, check that the network cable connection is working properly.
Dec 29, 2017 | Toshiba Satellite Laptop
Install to pc
Power on the computer and enter the BIOS menu. It will tell you which button to press to enter setup. Generally it will be F1, F2 F10 F12 or Del.
At this point you can insert your operating system disc.
In BIOS navigate the menus and look for Boot Order, or similar Make sure CD/DVD boots before anything else
Press whichever key the menu states to save and exit (Probably F10)
When the computer boots it should either start booting to the installation setup or ask you to press any key to enter installation. Do so and follow the prompts to install your operating system.
Post if you need more info.
Jul 12, 2011 | Computers & Internet
How do I get my Toshiba Tecra to boot from CD
Please restart the computer and press the F2 Key to enter BIOS Setup. Then follow the onscreen instructions to locate the Menu for Boot Configuration to select First Boot Device as the CD-ROM Drive or DVD-ROM Drive. Then select F10 Key to save the changes and Exit. Now insert any bootable Operating System Disc and restart the computer to boot from the CD.
Mar 27, 2011 | Computers & Internet
I have dell inspiron laptop, suddenly a problem occured I quot that :windows faild to start a recent software or hardware change might be the cause to fix the problem : 1-insert your windows...
Shut your computer all the way down. As soon as you turn it on, start hitting F8 about 3-4 times, that will take you to an advanced options menu. Select "Last known good configuration" and that should work
Mar 08, 2011 | Computers & Internet
I forget the hdd password
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 15, 2011 | Computers & Internet
When turning on my acer aspire desktop a black screen comes up with the following and wont start up: Verifying DMI Pool Data...... Update Success Boot From CD: DISK BOOT FAILURE INSERT SYSTEM DISK AND...
Ensure that you havent got a cd in the cd rom then reboot, press F2 or Delete to enter the bios and look for boot options, set the primary boot to your harddrive press F10 and press y to save and exit the bios, Press F11 and set that to boot from harddrive and let the computer boot, if it still dosent boot to windows then the hdd has become faulty, or has been wiped of the operating system and windows will need to be reinstalled.
Aug 21, 2010 | Acer Aspire™ T180 PC Desktop
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
I want to get into the setup mode when booting, and the normal F2, F8, or F12 keys don't do anything. I want to boot from a cd....how do I achieve this?
its possible that the Function keys on the top of your keyboard aren't working.
Turn off the computer and disconnect the keyboard from the computer and then plug the keyboard back in.
If the keyboard function keys still aren't working then the keyboard needs to be replaced.
Just for your info, to boot up off the cd you would either go into the BIOS by pressing F10 or F11 on your keyboard and then change the boot sequence so that the CD Rom is the first boot device.
You can also press F12 to go into the boot menu and choose the cd-rom directly from there.
Aug 04, 2009 | Compaq Presario 5000 PC Desktop
New build computer boot problem
The exact problem is not actually a problem.Just get in to BIOS.
As it is a new system, even if you get to boot from HDD it would say insert proper boot device and press enter or your floppy drive is in first boot.Check you boot settings.
Change the boot order as below.
  • 1st boot device:CD drive
  • 2nd boot device:Hard drive
  • 3rd boot device: anything you want
Now save and exit(F10 then Enter)
Now your PC will reboot.
Drop in the OS CD (Xp , LINUX or whatever)
Install the OS .Now you are ready to use your PC.
Mar 18, 2009 | Intel Computers & Internet
HP Compaq FS7600 17" CRT Monitor Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
