Question about ATI RADEON 7000 PCI Graphic Card
Install Used ATI 7000 graphics card on Dell Optiplex GX270
Is there an old card I need to remove. the only slot I saw to place the new card in was Green. The ones that were white , the new card did not fit in properly. I downloaded a new driver from the internet for the new, used card.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    I have a feeling the video card you bought may be an AGP board and your computer has a PCI-Express slot. The Dell website is down at present.
    President:
  • 1,901 Answers
OK, I got into Dell. Your motherboard should support an AGP card.
GX270 System Boards
Is there something in the green slot?
That is the AGP slot. If there is something in it, remove it. The ATI card should work in it if it is an AGP card.
Posted on Feb 12, 2009
  • Wayne Mineard
    Wayne Mineard Feb 12, 2009
    Just to verify...is this your card?
    This is the AGP 32 bit version. The 64 bit version has an S-video connection.
Can get wireless on my dell gx270
Most desktop computers do not have a wireless card installed.
You need to install a wireless card in the expansion slot and install the wireless driver, then configure this wireless card with your router's wireless settings so it can connect to the wireless router.
Aug 11, 2011 | Dell OptiPlex GX270 PC Desktop
Hello I have a Dell optiplex GX270, with the mobo it comes with. It will boot, has sound coming from the HD, CD drive, cpu cooling fan, etc, but will not show anything on the monitor and the keyboard...
Hi,try swapping the Memory chip ie putting it on the other slot,also test with another processor if after all these system does display,i'll suggest you go get a new board.
Jan 04, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
I switched my video card, I now have no taskbar or start menu
MAYBE CONFLICK WITH HARDWARE OR AND SOFTWARE, REMOVE THE NEW CARD AND RE INSTALL THE OLD ONE FOR NOW.MAKE SURE IT WORKS
INSTALL NEW HARDWARE, DONT PUT THE SCREW IN CARD YET
REBOOT
GO TO CONTROL PANEL AFTER BOOTING
OPEN ADDING NEW HARDWARE
LIT WIZIRD DO ALL THE WORK AND IF YOU CONTINUE TO HAVE PROBLEMS THAN YOU HAVE HARDWARE UNCOMPATIBLE HARDWARE
ROD
Feb 28, 2009 | ATI RADEON 7000 Graphic Card
Dell Desktop DX270 doesn't work with LG w2052TQ monitor...
A Dell Optiplex GX270 can have either on on-board VGA integrated graphics controller or an expansion graphics controller. If an expansion card is installed, the onboard graphics is disabled.
So first, ensure that the VGA cable is connected to the correct graphics connection (If there is an expansion slot with a video connector, ten you must use that connection)
If connected to the correct port on the system, next ensure that the input select for the monitor is either set to autoselect or ANALOG
Last ensure that the display resolution of the graphics adapter will support the new monitor.
Feb 05, 2009 | Dell OptiPlex GX270 PC Desktop
Upgrading Graphics Card
So your dell only has a AGP slot.
You need a AGP card
On nvidia side you can get
The geforce 6000 - series
Geforce 7000 series
On Ati side you can get
Radeon x1000 series
Radeon HD 2000 series
Radeon Hd 3000 series
Remember they have to be AGP
May 26, 2008 | Dell Dimension 8100 PC Desktop
Problem with computer
Try a good cleaning. Unplug the power cord from your PC. Remove the sides of your case. Using air blow everything off.
CPU, heatsink & PSU from both sides /outside to in & inside to out. Than remove the video card and clean its slot. Than clean the card its self. It would not hurt to remove your memory and clean their slots, reseat. Update windows!
If your broblem stops your done. If is hasn't doenload the latest driver from ATI: http://ati.amd.com/support/drivers/xp/radeon-prer300-xp.html Remove old drivers from control panel before installing new drivers. If your old drivers fail to remove. Download & run ATI's uninstall utility:
http://searchna.ati.com/promosearch/?site=us-en&la=en&qt=cat-uninstaller&selectsite=ATI&sp_a=sp10039240&sp_p=all&sp-x-1=col&sp_f=ISO-8859-1&sp_q=cat-uninstaller&Search.x=9&Search.y=8
Dec 26, 2007 | ASUS A9250/TD Radeon 9250, (128 MB)...
ATI RADEON 7000 PCI Graphic Card Logo
1,931 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
