Question about Bestec ATX-1956F (ATX1956F) 200-Watt Power Supply
ATX-1956Fpower supply problem
With out mother board connection ,all the voltage are ok,fan rotate,with mother board connection power supply is dead.
    Problem Solver:
  • 13 Answers
Clean the RAM and try again. Use an eraser on the 'teeth' of the RAM. Disconnect all drives and roms and try start with only the MB to get a display. Try get the alarm system working by fixing a MB speaker. This is very helpful and saves time in diagnosing MB problems.
Posted on Oct 29, 2012
    Problem Solver:
  • 14 Answers
Check another power supply to connect in mother board and then confirm mother board problem that means mother board power ic problem.
Posted on Feb 12, 2009
    President:
  • 778 Answers
Sounds like the MotherBoard is dead?
The power shuts down as soon as it comes on. Fans start, lights come on, then it turns off.
it may be your power supply : if one voltage aren't good the mother board automaticaly shutdown to prevent damage
or it could be CPU, RAM or motherboard but i think that it's the PSU
Oct 28, 2012 | Intel Motherboard
MY PC SHUT DOWN NOT WORKING
Try to check the power supply, if the fan rotates as you turn it on, the try to open it and look for the motherboard capacitors there maybe some leaks on it. but if you have a spare or extra power supply try to change it. maybe you power supply brokes.
Jul 12, 2011 | Biostar G41D3 - Motherboard - micro ATX -...
Died. nothing comes on, so not dead drive. switched out power supply, so not dead power supply. the switch on the front - blue led only comes on when plugged in lower right two prongs of 8 (4x4). So, tried...
short power switch pins on mother board, reset bios, short green wire to black wire on ATX connector with all drives etc.. power cables disconnected to test power supply. i suspect you have a dead motherboard.
Jun 20, 2010 | eMachines ET1161-01 PC Desktop
No power at all. what and how to check
Unplug everything but the motherboard and front panel connections. Remove any cards (even the video card) and ram and see if the system comes up (you should hear error beeps and get lights). Install the ram next and retry if the power is up. At the point where the disappears you have found the bad component/ device. If no power lights with everything disconnected but the processor the power supply is bad or mother board is bad. The switch on the power supply is set for your line voltage correct?
Oct 24, 2009 | OCZ StealthXStream / 600-Watt / ATX /...
Pc not switching on even after changing smps. even fan not switching on in smps
Dear,
You can test you smps simply by shorting any of the back wire and green wire. this will switch on your smps withour connecting with mother board. IF it the fan rotate, SMPS is ok.
If you need more trouble shooting on SMPS you have to measure the volate on each wire after powering on.
More info http://www.smpspowersupply.com/connectors-pinouts.html
Oct 13, 2009 | E-Machines 230W Micro ATX Power Supply,...
No power
ok dandan, please tell me you live in nj. I am having the same problem with my puter and did every step you did what is up with this??
Jun 12, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Mother board servicing
Have you verified that the PSU is OK.
DO you have a voltmeter?
Check the voltages on the main connector to the board
HERE is the 24 pin ATX connector
HERE is the 20 pin ATX connector
If the voltages are not there then either the PSU ON signal is not there, the ON switch is faulty or the PSU is dead.
Post back results and I will try to assist furher
Jul 09, 2008 | ASUS P4S8X Motherboard
Power supply
angeldram3
as i think ur processor over heated. or processor can dos not work fine or heat sink not installed properly. remove heat sink, and use heat sink component (a whithe colour gel. u can buy it any computer accessories shop) use it top of ur processor then attached heat sink. and connect processor fan. before installing heat sink check processor fan. then cleare CMOS by removeing battery (because this problem also can happen wrong frequency setting in CMOS setting).
Jun 29, 2008 | Gateway Bestec ATX-300-12EB3 305w Power...
Pc will not power up
Swimmie
to chack ur power supply open all connector from system board and drive. then conect power cable with powr supply and powr on ur wall outlet switch. than take mother board connector find green color wire and take a small pice of coper wire and connect it with this green wire and a black wire. then chack smps fan is moveing or not if it's moveing then ur smps OK.
Jun 27, 2008 | Okia / 450-Watt / ATX / 80mm Fan /...
Mother not working
You blew out the motherboard, cpu & ram may have survived, but I would guess that high of a voltage would have fried the mobo
Jun 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Bestec ATX-1956F (ATX1956F) 200-Watt Power Supply Logo
609 people viewed this question
Top Bestec Computers & Internet Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
