Question about HP Compaq Presario V2405us PC Notebook
Laptop won't power on
My laptop worked great. I decided to upgrade the ram to a 2g. I went to my local Staples store and bought one and took it home and put it in my laptop. It wouldn't power on so I took it back to Staples and they gave me another brand which I returned cause it also wouldn't work. Put my own ram back in but my laptop still won't power on. I get nothing at all. Could this ram have fried my laptop? Or is there a fix for this.
  • 1 more comment
  • Anonymous Feb 13, 2009
    Its my sisters laptop and I don't think she removed the battery before she put the ram in. I have tried to remove battery and try just the AC but still nothing.The power cord works, she uses it on her other laptop. I double checked to make sure ram is in correctly and it is. I tried to hold power down still nothing. No lights at all even when AC plugged in. I just can't figure this one out. There is absolutley no power at all.
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    The last thing I can suggest is to make sure no connections were loosened inside when you removed the cover and replaced the RAM.
    If everything looks secure, and if the AC adapter is the correct one, and you see or hear nothing, I can only surmise that you either have a fuse blown, if there is one, or the system board was damaged. Either way, it is something that you should let a knowledgable repair shop check out.
    The AC adapter IS the one specifically used for that computer, correct? I am assuming it DID work at one time. Just asking. Not all adapters are interchangable.
    Just keep this in mind in the future: Always remove ALL power sources when replacing ANY parts inside a computer. Even after removing the power sources, hold the power switch down to "bleed" all the capacitors inside.
    Sorry I could not be of more help.
  • Wayne Mineard
    Did you remove all power, including the battery, when you replaced the RAM?
    Are you sure the RAM is snapped down into the clips?
    Will it not do anything with battery or AC power? No LED's? No fan?
    Hold the power button down for a few seconds and see what happens.
    Sergeant:
    Champion:
  • 283 Answers
Check the power light indicator if it work when turnig on the laptop. If doest work replace the power supply
Posted on Feb 12, 2009
Asus F3Q will not turn on
The connections at pins and holes could just be dirty or possibly the solder is broken loose inside the recepticle in the Asus.Latter is most likely.If you're into fixing it,and the soldered connections in receptical are bad,luck to ya friend.Would but be a good unit to upgrade to Windows 8 with an Intel processor and 4Gb RAM,even a 500 GB hard drive.Hmm,may a swell just buy a NEW ONE.I'm kidding.I personally like working on computers.I've kept this 2008 Toshiba running since August 08.Done probably 10 or 12 re-formats,3 different hard drives,went 4GB RAM and back to 2 GB and made no difference in speed.I'm about to retire this one this week and go to the Asus that I found on sale at Staples for $279,with all the fine bells and whistles I spoke of earlier.Have a food day.Regards,Rigger.
Apr 15, 2014 | ASUS F3Q-AP003E T3200/2.0/320/2G/15/XPP PC...
I decided to upgrade the memory from 512 mb to 1 gig. It was working slow but i was ok with it. I was on battery and i thought i would plug in the power so it would charge...and then the screen started to...
you should be able to upgrade the ram to 2G but it must be compatible. I usually choose Kingston Value Ram or Crucial ram after checking their compatibility list.
Jul 03, 2011 | ASUS Eee PC 900 Notebook
I bought Toshiba Satellite A80 Laptop Pc 4 years ago. I want to make memory upgrade by myself. How can i do this ?
Simply take the laptop to Staples or any computer store and any associates will show you all the available RAMs recommended for you laptop because they have a cross reference data base - if the upgrade don't work, they'll buy it back or get you one that will. You won't have to spend unnecessary time doing the research yourself.
Dec 21, 2010 | Toshiba Satellite 2060CDS Notebook
I'm having problems upgrading the RAM in my Packard Bell Easy Note Argo C. I bought 2G of the exact same RAM that is already inside but it's not working. What shall I do?
Victoria,
It is not that you can add any amount pf RAM to ant PC/laptop. Each motherboard has the TAM quantity fixed and you cant exceed it. It may be less than that quantity or equal but not more. So must be the case with you.
Nov 15, 2010 | Computers & Internet
Memory upgrade
try to change slots of the Ram. Still if it's not working try only with new RAM to check if new RAM is working fine or not.
May 04, 2010 | HP Pavilion dv6245us (RP285UA#ABA) PC...
Can I upgrade ram of my Dell inspiron1545? if yes, to what extent can I?
Yes, you can upgrade RAM of your Dell laptop. When you are upgrading purchase a RAM which is compatible to you laptop (or you may buy the same RAM but the speed are fast). I think 2g to 4g is enough RAM to run to your laptop.
Dec 14, 2009 | Dell Inspiron 1545 Notebook
Ram upgrade problems
looks like you have the wrong ram for your system Kingston is showing this for your system KVR667D2S5/2G
but try refreshing your bios i doubt it will work but give it a shot with your ram installed just hit F2 to get into bios when starting your computer save and exit that should refresh it
Nov 03, 2009 | ASUS Eee PC 900HD Netbook
Asus 1000 freezes after 2g ram upgrade
Go into bios and make sure mem is set to auto find ,might help
Feb 24, 2009 | ASUS Eee PC 1000 Notebook
Wont start up after ram upgrade
Try reseating the memory and if that doesn’t work, install the 512’s one at a time to see if one might be defective. If the laptop still won’t turn on, reinstall original memory and see if laptop powers on.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 20, 2008 | Dell Inspiron 1100 Notebook
HP Compaq Presario V2405us PC Notebook Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
