Question about Linksys Wireless-G WRT54G Router
No Passwords Accepted
I have a Linksys Wireless G Route (WRT54G). Set up my home with 5 Computers. 2 Wireless 3 desktops. At the moment, it's 1:30AM and I am the ONLY person online. I have unplugged & held reset button for over a minute. 5 minutes for unplugg and a little over a min for reset button. I am trying to get into the router to set up the wireless security. That being said I AM plugged directly into the router and able to use both LAN and Internet capabilities. When ever I try to load http://192.168.1.1 I get the login prompt and I enter the login/pass. 401 access not allowed. I've tried User names: (None), Admin, Administrator. Passwords: (None), Admin, Administrator, password, 1234, ect. I have tried all cobminations and with both IE and Firefox... I'm at a complete loss. Is the router broken?
    Problem Solver:
  • 14 Answers
If u have the switch
for the three desktop OK
Then connect your LAN cable directly to the router.
listen connect cable switch to router then router to laptop and then give automatic ip address in your laptop OK or ipconfig /release give this command and then give command ipconfig /renew then connect to your 192.168.1.1 its connect ok
Posted on Feb 12, 2009
Find ssid number for linksys model wrt54g
SID broadcast allows computers to quickly locate a new network and connect to it. In wireless home networks computers often use only the home network, which makes SSID broadcast unnecessary. Disabling SSID broadcast adds a bit of security to your wireless network, because computers won't be able to see your network's SSID.
Log into the router.
  1. Open your webbrowser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. Type your login info in the login screen. Default: 'admin' (without quotes) in both fields.
  3. Go to Wireless > Basic Wireless Settings 'wireless
  4. Set SSID broadcast to 'disable'.
  5. Click Save Settings.
On the next page you will set a router password to prevent unwanted visitors from accessing your router setup.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
How to set passwords?
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and putit in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 22, 2011 | Linksys Wireless-G WRT54G Router
Linksys wrt54g secure easy setup
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
http://192.168.1.1
You can protect your router by changing the default PW (write it down and putit in a safe place)
Aug 15, 2011 | Linksys Wireless-G WRT54G Router
I secure enabled my wireless route now I can't access it.
http://192.168.1.1
Apr 28, 2011 | Linksys Wireless-G WRT54G Router
Router pasword
Default user names:
  • Linksys BEFW11S4, WRT54G: admin
  • Linksys EtherFast Cable/DSL Ethernet routers: Administrator
  • Linksys Comcast routers: comcast
  • All other Linksys routers: [none]
Default passwords:
  • Linksys BEFW11S4: [none]
  • Linksys Comcast routers: 1234
  • All other Linksys routers: admin
Dec 07, 2010 | Linksys Wireless-G WRT54G Router
Network/router problem
Is your router wep or wpa encrypted if so you need to put that wep key into your new laptop so you can connect to it.
Oct 17, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G can't connect 3rd wireless computer
log into the WRT54G wireless router and ensure that you do not have it set up for only handing out 4 IP addresses also check the laptop to see if it is set to have a DHCP or static IP address, if it has a static IP and your network is dynamic then this is why it wont connect.
if this resolves your issue and you are happy with the answer please grade me accordingly.
thanks
Aug 25, 2009 | Linksys Wireless-G WRT54GS Router...
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
Want to password protect my wireless router
check out this link to solve your problem: http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3967
Mar 10, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Linksys Wireless-G WRT54G Router Logo
63 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
