Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Unable to delete the autorun.inf
Windows xp
  • Anonymous Feb 12, 2009
    same here
    how can i do in.autorun virus deleted
Hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Posted on Mar 16, 2009
    President:
  • 1,952 Answers
First run your system in safe mode, then go to your my computer properties and enable the system restore function.
then restart your computer and run in command prompt mode. in the command mode type the following.
ATTRIB Autorun.inf -H -S -R.
if the file is found in the Drive then give.
DEL Autorun.inf.
<similarly you can do it for all drives. but you have to restart your system for each drive.>
Posted on Feb 12, 2009
5 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: trojan horse-zlob.x_a
http://www.trojan-zlob-removal.com.removal-instructions.com/removetrojan.zlob.html
Posted on Dec 22, 2007
SOURCE: autorun.inf virus
same problem
Posted on Mar 10, 2009
asthanarht
  • 258 Answers
SOURCE: unable to delete autorun.inf
try to delete it in safe mode.........
Posted on Mar 30, 2009
ramketh
  • 12 Answers
SOURCE: autorun.inf virus prob.
go to start button and press run option type cmd type cd\  2. type c: and press enter
3. type attrib -r -h -s autorun.inf
4. type del autorun.inf
Posted on Apr 02, 2009
Delete autorun inf virus 4gb
If you have a autorun.inf virus on your memory card/USB stick the anti virus software on your PC may not allow access in order to stop it from spreading.
First you need to disable autorun feature on Windows operating system :
Follow steps in link :
http://www.redmondpie.com/how-to-disable-autorun-autoplay-in-windows-7-and-windows-8/
After disabling the feature you will have access to your memory card/USB stick. The next step is to delete autorun.inf virus file hidden on your memory card/USB stick. But first you need to make the hidden virus file visible.
Follow steps in link to show hidden system files :
http://www.bleepingcomputer.com/tutorials/show-hidden-files-in-windows-7/
Now navigate to your memory card/USB stick you should see the autorun.inf file - DELETE IT.
(If it doesnt allow you to delete it - restart the PC in safe mode by pressing F8 on start up and choosing safe mode and try again)
Back up your files on the memory stick/USB stick to your PC and to make sure the virus is gone from the memory stick/USB format it using your PC.
Dont to forget re-hide your system files to prevent accidental deletion.
Oct 15, 2013 | SanDisk 1GB microSD Memory Card
I use a cruzer 4GB to go between my Mac & my work PC. Now, on windows, it says I have a possible worm virus. When connected to my Mac - there is no virus. Something to do with something called...
I believe that Windows is having an issue with the information in the autorun.inf file.
The entire sequence is initiated when the "disk change notifcation" polling discovers a new disk in the CD or DVD ROM drive. Then, if the "Auto insert notification" feature is enabled (it is by default), Windows checks in the new disk's root directory for the existence of an "autorun.inf" file. If found, Windows then reads and follows the specific instructions this file defines. If no autorun.inf file is found, then Windows refers to the new disk by its serial number and executes the default actions associated with the (data or audio) content on the disk.
My suggestion would be to delete the autorun.inf file as it is not needed.
Aug 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problem with windows xp
Sometimes it happens in windows XP that you are not able to open drives on your hard disk. When you double click on the drives icons or right click on the drive>>explore in My computer ,the drive does not open.
This problem is generally caused by most of the viruses which infect windows XP system. They block or restrict your access to any of the drives.
But don’t worry this is not a big trouble it can be fixed easily.
Fix:
Normally when a virus infects a windows system which causes a drive opening problem, it automatically creates a file named autorun.inf in the root directory of each drive.
This autorun.inf file is a read only ,hidden and a system file and the folder option is also disabled by the virus. This is deliberately done by the virus in order to protect itself. autorun.inf initiates all the activities that the virus performs when you try to open any drive.
Very simple . virus create some bad registry if you want to solve this problem then delet this registry
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion­\Explorer\MountPoints2
delete all drive from here
May 11, 2009 | Microsoft Windows XP Professional
Autorun.inf virus prob.
Apr 01, 2009 | Microsoft Windows XP Home Edition
I cant open disc D?
u can open drive D by typing "D:\" on the address bar or RUN
there is a hidden files u must delete them, to solve ur problem try these steps :
Go to command prompt and write this command
c:\> attrib -r -s -h autorun.inf
c:\> del autorun.inf
d:\> attrib -r -s -h autorun.inf
d:\> del autorun.inf
restart the pc
it will be solved
contact me if this problem still exist
Mar 14, 2009 | Computers & Internet
Autorun.inf virus
no antivirus needed
goto control panel and choose a box that says shown hidden files and folders and delete autorun.ini in the folder that has the virus
Mar 03, 2009 | Microsoft Windows XP Home Edition
Can not find script file "C:\ntidr.vbs"
by alvin:
just go to command prompt, click run then type cmd..
after that type dir f:\/a/w if letter f is where your drive located..then you can see the contents of your drive ..you will see an autorun.inf...
you should delete that...in the same cmd window
type attrib -r -a -s -h f:\autorun.inf
then type del f:\autorun.inf....eject your flashdrive...goobye ntidr.vbs..
Sep 21, 2008 | Microsoft Windows XP Home Edition
Taskmanager
use virus online scanner. you have viruses
May 05, 2008 | Microsoft Windows XP Professional
Trojan horse-zlob.x_a
go to folder options then untick hide operaing system files then u can find autorun .inf in drive delete t and reboot .
Dec 22, 2007 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
1,118 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
