Question about Dell 5650 Computer Speakers
Can you get sound if you are missing the central speaker?
Husband threw it out with old monitor. I have been unable to get subwoofer and 4 speakers to work without it. if this doesn't work where can I buy a replacement for this speaker?
  • Anonymous Mar 16, 2014
    I purchased a princeton vl158 monitor and am unable to get the speakers to work. They worked on the very old monitor I had before
Clearly, the most efficient and effective answer...would be to leave that husband.
Posted on Aug 07, 2015
    President:
  • 778 Answers
Self powered speakers are configured to get their voltage from a source outside the PC, so you'll need to replace the central unit that provides the power or replace the speaker system. As for a replacement you can Google the Brand Name and model of the speaker and you may find a source for a replacement that way.
Good luck.
Posted on Feb 12, 2009
I purchsed a new LG Monitor and installed it to my 4 year old Gateway Computer,now have no sound coming from my Bose speakers! HELP?
I answered this but the solution did not post (thanks to Verizon). When you installed the LG software, were you prompted to change any settings? The LG software may have hijacked your normal sound output to your Bose speakers
Nov 18, 2012 | LG E2242T-BN Black 21.5" 5ms Widescreen...
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
The subwoofer is only putting out about 10% of it's capacity
if the speaker is actually receiving signal and has sound, the next question is if the sub is self amplified or not. if it is check the amp in it. if not then check your unit to make sure the bass is not turned down and that the correct surround setting are there. there is also possibility that the show or item your listening too isn't outputting correct channels.
Mar 29, 2010 | Monitor Audio Radius R360 Subwoofer
I think my speakers have blown they sound quite bad and no base to them can they be repaired or would it be cheaper to buy new they are monitor bronze br2 they are only 1 and half years old perhaps i didnt...
If a speaker goes "bad" it usually can not be fixed. Speaker systems use different speakers for different tones. This sounds like the speaker used for bass is not working. Check if there is a fuse in the speaker cabinet somewhere. Also, is there bass gone on both speakers?
Sep 12, 2009 | Monitor Audio Bronze B2 Main / Stereo...
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Replacement subwoofer
1st, if you want a new speaker(just the sub, not the cabinet), ask Mackie for the nearest dealer.
2nd, If you want to have the speaker reconed, I can recommend :
Central Florida Speaker
714 W. Smith
Orlando,FL 32804
407.423.6566
They do good work.
Nov 14, 2008 | Mackie HR824-MK2 System
Missing parts
i have the subwoofer but not the speakers and sound touch control center, wires or guides due to fact that they are stolen. could you help me fix this problem? i love the old one as i do not want to buy another system.
Jul 26, 2008 | Logitech Z-560 Computer Speakers
I tried to increase the sound on my hannspree HF2229H ..sound lost
CHECK FOR THR DRIVER'S IF ARE OK. IN DEVICE MANAGEMENT,
May 25, 2008 | Hannspree HW191D LCD Monitor
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
Dell 5650 Computer Speakers Logo
433 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
