Question about Toshiba Satellite M35X-S161 Notebook
Laptop fan is running continuously
My laptop fan is running continuously and my mouse is stuck. i tried the FN F9 idea and it didn't work.
  • david2476 Feb 12, 2009
    the regional code on my COMPAQ laptop is locked on regional code 1 when it should be on regional code 4 to play DVD'S
    President:
  • 778 Answers
The cooling fan in a laptop/notebook should run at all times that the laptop is powered on, though the speed may vary with temperature. As for the mouse, updating the driver may correct the problem, you can connect a USB mouse to work on the problem until it's solved.
Posted on Feb 12, 2009
  • test815 Oct 28, 2010
    Read this article for your fan problem, a shop vac may be all that is needed.
    Why my Toshiba laptop suddenly shuts down by itself without warning?
    “My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
    http://www.laptoprepair101.com/laptop/20...
Mouse touch pad not working
'F9' keys has a mouse, no mouse looking symbol. sometimes you use the 'Fn' key in conjunction with 'F9' key, sometimes not. Give it a try by itself and use it. If not hold the Fn key and hit F9 and try again.
Jan 08, 2014 | Toshiba Satellite A355-S6925 Notebook
My onborad mouse on my toshiba Tecra A3 pta3u14004 is not working how can I fix it
You can enable or disable your onboard mouse with Fn+F9
TouchPad Enable/Disable ( Fn+F9 ).
Regards
Jun 03, 2011 | Computers & Internet
How can I disable the trackpad to only use an external mouse? Toshiba laptop (Satellite)
For most Toshiba laptops, you should be able to hit FN+F9, and it will disable the touch pad. If that doesn't work, go to your Control Panel, Hardware and Sound, Mouse, and disable it there. Hope this helps!
Mar 28, 2011 | Toshiba Satellite 2400-S251 Notebook
My mouse pad does not work nor does USB cable
Has the mouse lock been applied.
Press and hold the "FN" key and then press "F9" this should unlock the mouse and touch pad.
Failing that try updating the drivers for both using the device manager as I have found that recent updates have disabled my touch pad and I have rolled back the drivers to the previous ones.
Aug 15, 2009 | Acer Aspire One AOA110-1588 Notebook
Frozen mouse icon
press fn key along with f9 to enable and disable the mouse pad. some laptops use diffrent keys so it isn't always F9. usualy there is a mouse pad icon on the key.
Jul 28, 2009 | Toshiba Satellite M35X-S161 Notebook
Mouse pad locked
Try the F9 key(hold the FN key and tap F9)
Jul 12, 2009 | Acer Aspire 5720-6661 Notebook PC
My mouse button is lock how do i unlock it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Jun 25, 2009 | Computers & Internet
Frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Dec 29, 2008 | Toshiba Satellite L305D-S5895 Notebook
Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
To get enable or disable the Touch Pad you have to pulse the Fn + F9
You can also set this function as follow:
Start >> Control Panel >> Printers and other hardware
Click Mouse >> Touchpad (enable or disable)
Oct 27, 2008 | Toshiba Satellite A15-S157 Notebook
Touchpad is not working - TOSHIBA Satellite A135-2386
Hey there... :D
Could you try the Fn+F9 Key to Disable/Enable your touchpad mouse?
Because just now i've experiencing the same problem as you guys... and turns out I can make my touchpad working just by pressing the Fn+F9 key.
Note: if your Fn key is not working try installing Toshiba utilities for A135 called FlashCard, run the program and there will be a dropdown menu at the upperside of your screen...
then click on F9 >> and choose Enable.... Thats It... :)
I hope it also solved your problem... :D
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite M35X-S161 Notebook Logo
158 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
