Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
I can't move to partition (C)
i have been use is windows vita home prenuim nowaday. but I neet to change to be XP i can't change, it isn't move to chenel (c)
  • JP Ortiz May 11, 2010
    What do you need to change to xp? are you trying to go from vista to xp? are you in a dual boot OS?
  • ashish13
    ashish13 May 11, 2010
    It is possible to install XP on a vista system by first formatting the system n booting with an XP bootable disk, but before doing that one needs to make sure if your computer has driver support for XP n also if Vista came preinstalled on your system then by installing XP u will be voiding the warranty..
  • 36 Answers
You can boot from a windows Xp cd
so you can reinstal windows on ur C partation
Posted on Feb 13, 2009
I want to install ubuntu and Mandiva, my question how to Install both operating systems? Thanks
The answer is yes, and no.
Both Mandriva and Ubuntu are Linux based and they do have
similarities and differences. The differences in how things run
may cause you problems, so the easy answer is no. There are
similarities that can be shared, and in this case, you have a
yes.
Since you mention XP and Ubuntu halves above, I'll assume you
have your harddrive split in only 2 partitions, perhaps or
preferably 3 partitions, such as.
hda1 = C: = XP ntfs (maybe 15 to 40 GB in size)
hda5 = extended partion which holds Ubuntu and swap
hda6 = = Ubuntu (maybe 4 GB or bigger and includes home)
hda7 = swap (approximately 2x the size of your RAM)
First, we begin by describing your hard drive geometry.
When IBM compatible PC computers came into existence, the hard
drives had definitions allowing the harddrive to be divided into
4 separate partitions. 1 of the 4, could be allocated as
an "extended" partition which could be divided further into many
more partitions. In the past, this allowed you to have 4
distinctly different operating systems on your harddrive, or 3
distinctly different operating systems and an extended partition
for extended drives, so in the past, it was possible to have
combinations such as DOS, Win95, OS2, and shared extended drives.
There were additional limitations, but based on you
describing "halves", your computer does not have the 1024
cylinder problem of long-ago and you are running a more modern
computer with a modern BIOS.
XP does want to be the 1st operating system on the 1st
enabled "primary" partition, so let us leave that as it is since
linux is more flexible and can be put on the extended partitions.
From a linux perspective, the primary reserved definitions would
be 1,2,3,4 (XP will me located in one of these 1..4) and the
extended partitions are 5 to define the partition, then
6,7,8,9.... (your Ubuntu will be located on one of these 6...).
Due to some very old software having had problems in the past,
you will want try to keep within the boundaries of 6,7,8,9 to
avoid problems (unless you are an expert at troubleshooting).
In linux, you may note that your hard drive is described as hda
or perhaps sda and a number.
If you type at the command line fdisk /dev/hda and then
choose "p" for partition definitions it should describe how your
hard drive is partitioned right now. Press "q" to exit.
I'll assume you do not know about moving and remounting
directories, so we'll go the easy way with more steps but less
chance of problems.
If you have not done anything particularly important on your
Ubuntu worth saving yet and don't mind reinstalling it, I would
recommend putting the /home in a separate partition which you can
share between Ubuntu and Mandriva, and also a separate /swap
partition that can also be shared. If you need to keep certain
things, then make a backup of what you want to keep and put those
aside to restore later. This is better done now before you
install Mandriva. We want to avoid some complicated moves later.
I prefer to backup my machine before causing some major changes
such as these, it is strongly recommended you find a method to
backup your computer at the hard drive "image" level so you can
recover from a disaster if something goes wrong. this may help if
you have another computer available with sufficient hard drive
space. Substitute windows "share" instead of Samba if the other
computer is windows based.
http://www.joescat.com/backup/disk_image.html
If the above does not work for you, just make sure you make a
backup you can recover from one way or another.
With your Ubuntu install CDrom divide and install your Ubuntu
somewhat like this (partition #s and sizes may vary)
hda6 = home = Ubuntu (to share with Mandriva, make it
sufficiently large)
hda7 = = Ubuntu (maybe 4 GB or bigger, does not have home)
hda8 = empty partition (same size as hda7 - not defined)
hda9 = swap (approximately 2x the size of your RAM)
I recommend in the order above since you should rarely if ever
need to use /swap (so it is at the very end of your harddrive),
and your /home is next to your XP C: partition, which allows you
to change and modify everything in between your /home and /swap
without having to modify your XP C: /home or /swap any more.
Next, get your Mandriva CDrom install disk, and begin installing
it, during install, you want to re-use the existing Ubuntu /home
and existing Ubunt /swap partitions, so you indicate during
install:
hda6 = home = Mandriva (to share with Ubuntu)
hda7 = leave as undefined (it is your existing Ubuntu ""
hda8 = = Mandriva
The values 1,6,7,8,9 may not be the same as they are assigned by
the partitioning tool, but the locations on the disk should be in
that order. Mandriva has resizing and partition moving options if
the partitions need to be re-sized, I think Ubuntu also includes
similar tools too. After finishing, run XP and do a command-line
chkdsk C: to make sure XP is happy with any changes you may have
made to XP's partition.
You should now have XP, Ubuntu and Mandriva with a shared /home
partition and a shared /swap partition. thanks
Mar 10, 2011 | Computers & Internet
I have partitioned my C drive and now have a 2nd
On the setup you need to select the xp partition if its not visible you will need to load additional SATA drivers when the setup asks you to
Mar 21, 2009 | Computers & Internet
Unble to formate the pendrive
Free Partition Software - MiniTool Partition Wizard Home Edition home1.png MiniTool Partition Wizard Home Edition is a free partition manager software designed by MT Solution Ltd. Our partition manager supports 32/64 bit Windows Operating System including Windows XP, Vista and Windows 7. Home users can perform complicated partition operations by using this powerful yet free partition manager to manage their hard disk. Functions include: Resizing partitions, Copying partitions, Create partition, Delete partition, Format partition, Convert partition, Explore partition, Hide partition, Change drive letter, Set active partition, Partition Recovery.
Dec 07, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How do i remove windows vista and install windows xp with out losing all my other stuff
If your Vista still work, go to the control panel> administrative tools> computer management > disk management > create an additional partition (larger then my documents folde size)
Move your files to this partition then install xp.
A few tips
  • Make sure there xp drivers for each componenet
  • Use driver magician and find xp drivers (check the pc mfg site and download all xp drivers and put them on this partiton too.
  • Use a partition program (dos) and format the vista partition and the hidden partition that vista creates or xp won't go in properly
Jan 24, 2010 | Microsoft Windows XP Home Edition
I have mainboard Amptron ZX-I945LM4,but i can't install any varsions of windows xp.i try change settings in bios,jumpers,but still same.tahnkl you for help
try to delete all of your partitions.
Then boot from cd the bootable setup disk of windows xp.
try a working setup disk.
1. if you still cant install windows xp,try to make a new partition and add all the contents of the setup disk into that partition. boot from cd and you will be able to go to setup screen.
Pm me if problem persists.
:) thank you
Aug 10, 2009 | Computers & Internet
Windows sp3 problems
If you're booting into a particular operating system which has another partition
optionally boot into:
When your system is fully loaded you click START.....RUN.....then type msconfig
and click OK. Click BOOT.INI and under "operating systems" view the order they
appear in and if the one you want to load on boot is listed second......highlight the
first one and click "move down". Next reboot the machine to view the change you've
made. Conceptual View
If you would like to delete a boot partition you'll need to right click MY COMPUTER
.....then click PROPERTIES in order to view System Properties. Click the ADVANCED
tab then under STARTUP AND RECOVERY click SETTINGS. This window will open:
Click the EDIT button and the boot configuration window will open in NotePad.
Highlight the partition you would like removed and press delete. Be very sure
to choose the correct partition because you can lose all of your data if incorrect.
When you reboot you will notice the deleted partition is no longer listed.
Nate P.
Jan 14, 2009 | Microsoft Windows XP Professional
Re-install OS/windows xp home
It only brings out one partition, and yes it gives me the option to either delete the partition or install on the partition or create another one.
Nov 02, 2008 | Microsoft Windows XP Home Edition
Running out of space on C drive
hi, its possible to merge two partitions.
down load a partition changing software like partition magic and install it. Have a look at the help available and and go for merge partition.
thank you
Aug 15, 2008 | Microsoft Windows XP Home Edition
When I boot up my computer before windows xp loads it asks which operating system I want to run,and it gives me 2 choices WINDOWS XP HOME, or, WINDOWS XP HOME. You use the up and down arrows to select...
simply you can remove the second option in the boot.ini.
go to the or right click the my computer at the desktop and the properties. and then click"advance TAb" in the start up and recovery, click "setting" and then "edit"
you will see this:
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(2)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
Timeout=30 change to: 0
and then delete this:
after deleting you must save it.
and then restart the system
Please leave a comment b4 your rate, Thanks!
Jan 28, 2008 | Computers & Internet
How to remove a second installation of a windows o/s
you would not have been able to install xp home over xp pro as pro is an upgrade from home, so xp pro will be on a different drive partition, so the last version you put on will be on the 'C' drive as thats the one that is bootable. Follow your instructions, or simply use your xp disc to format the drive and install XP home.
Jun 13, 2007 | Microsoft Windows XP Professional for PC
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
