Question about Dayton Electric Heater
Distance to keep between a 2000 watt heater & wall insulation?
I am installing a dayton wall heater. dont want the fiberglass insulation to catch fire.
    President:
  • 1,902 Answers
The fiberglass will not catch fire. There is a sfer barrier built into the wall heaters. When you install a wall heater you basically just cut the wall open and throw the unit in with the flue and gas and away you go. If you can to second guess take some of the insillation and take a match or a lighter and hold it in your hand and light the fiberglass, you will see that it wont burn even with direct flame on it. You are 100 percent safe
Posted on Feb 13, 2009
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
Can you wire up the heating element in a hot water heater wrong
you can indeed here are the steps to check you eliment
Turn off the breaker inside your main electric panel providing power to the water heater. Most electric water heaters use a 30-amp double-pole circuit breaker.
2 Look for the panels attached with screws to the side of the water heater. Depending on the size of the water heater, you will have one or two panels. Remove the screws from the panels to release them.
3 Remove the insulation you exposed when removing the side panels. Depending on the age of the water heater, the insulation is fiberglass or closed-cell extruded polystyrene foam. Wear safety goggles and gloves when removing fiberglass insulation.
4 Pull the plastic safety cover from the element face. This cover snaps on and off the element and thermostat.
5 Hold a noncontact voltage detector next to the wires connected to the element face, and next to each wire connected to the thermostat. If electricity still is present in the water heater, the voltage detector emits an audible alarm and its light flashes.
6 Loosen the two element screws. Remove the wires from beneath the screws. Make a note of the element wattage printed on the side of the element face.
7 Turn the dial on a multimeter to Rx1k (resistance times 1,000 ohms). Touch one of the screws on the face of the element with one of the multimeter probes; place the remaining probe on the remaining screw. A 3,500-watt element should register 16 ohms, a 4,500-watt element should register between 12 and 13 ohms, and a 5,500-watt element should register between 10 and 11 ohms. Replace the element if it does not register on the multimeter.
8 Leave one of the probes touching one of the screws on the element face. Touch the other probe to any metal part of the water heater. If the multimeter needle moves, the heater element is grounded, and it must be replaced. Make sure you test both screws on the face of the element.
9 Touch each screw with one of the multimeter probes. Place the remaining probe against the metal base attached to the element where it enters the water heater. The element is bad and must be replaced if the needle on the face of the multimeter moves.
10 Attach the wires back to the face of the water heater element. Snap the plastic cover back over the thermostat and the element. Reinstall the insulation and attach the panels to the side of the water tank. Turn the breaker on to the water heater.
Things You Will Need
  • Screwdriver
  • Safety goggles
  • Gloves
  • Noncontact voltage detector
Mar 06, 2015 | Water Water Heaters
When installing this heater in the wall ,how close can any insulation be to the heater ?
If you're talking about fiberglass insulation in the walls, you should be able to just have it right up against the heater. If you have the heater instructions, check on "clearances" page and make sure from the manufacturer how close combustibles are supposed to be to the unit. These units don't get real hot, so they are generally not dangerous.
Aug 18, 2011 | Dayton 3UG56 Electric Heater
I have a Rheem 82V52-1 Fury Electric Water Heater. The breaker keeps tripping atfer about five minutes of use. I uncovered the Bottom Element and Tested it with a Multimeter. Reads about 6 Ohms, Seems...
Protect yourself.
If water heater is tripping breaker and water heater is wet, then danger of electrocution.
Turn off power.
You do not need special element. Local home center and hardware sell generic elements.
Check side of tank for element wattage, usually 4500 Watts.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If fiberglass insulation is wet, you need new insulation because the insulation and cover cannot be left off the heater.
If thermostat is not covered with insulation, then cooler air will cause thermostat to mis-read temperature, and tank will overheat.
Putting a wet water heater back into service is dangerous.
Manufacturers suggest replacing flooded water heater.
Local Lowes here sells new 40 gallon electric water heater for $207.
Loosen anode rod before installing.
http://waterheatertimer.org/Replace-anode-rod.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 27, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Hi, I have a small Williams direct vent heater 14k btu that i want to install. for ideal placement, the double wall vent will be against the stud not centered. is this a problem? also can the existing...
The vent pipe CAN NOT touch the wall stud. You can cut back the fiberglass insulation, but it must be a minimum of 6" away from the vent pipe on all sides.
Jan 26, 2011 | Heating & Cooling
Cold air leaks in around the unit while it is not running. How can I insulate the air intake so that this does not happen?
Is this unit tight against the wall?
Can it be pulled away from the wall, without too much difficulty?
You need to be sure the leak is outside of the flue pipe going thru the wall to the outside.--
Or is it leaking in thru the inside?
If the leakage is due to a gap between the flue pipe and the hole thru the wall, then attention needs to be given to the flashing, and the air tight seal at the outside of the penetration...
Was a metal collar installed-- TIGHTLY against the flue pipe?
How was the needed air space (for fire prevention) made between the HOT flue pipe, and the framing materials?-- Then outside of that, how was the gap insulated?- (Non burnable-- like fiberglass can be used-- but it all depends upon the outer and then inner METAL seal rings being tight.)
Tell us more about where you are feeling the drafts..
Mack B
Dec 28, 2010 | Williams 3003622 Ceramic Wall Mounted...
Electric Hydronic Baseboard Heater Under Electrical Recepticle
I believe you interpretation of the code is a bit skewed in that the fundamental concern is to not route power cords over a heat source which might cause the insulation on that wire to exceed its rated operating temp and fail. The heaters themselves have shrowds over them so there are no exposed surfaces hot enough to melt wire insulation and when you think about it ..2000 watts disipated over a long baseboard section is not that hot. If I were you, I would go ahead and install them and not worry about the warning.. The warning also removes any liability from the heater manufacturer in the event something happens.. Common sense would dictate that you wouldn't intentionally drape power cords all over the heaters... Just use common sense and not worry about it..
Regards,
Rick
Dec 01, 2008 | Marley Electric Hydronic Baseboard Heater,...
High Altitude Electric Heaters
I have never heard of altitude effecting the electric. Watts amps and volts are different than burning a gas, like propane. The high altitude has less oxygen thus requiring the combustion to be effected. If your wires are over heating when you use maximum wattage (amps) you need to install larger wire with the correct size breaker. Look up ohms law. Its a basic electrical formula and will help you get this right.
Dec 26, 2007 | Dayton Electric Heater
Dayton Electric Heater Logo
257 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
