Question about Planet Audio VX602 Car Audio Amplifier
Planet audio vx602 amp external blue light is out
Do I have to replace a bulb or is it not fixable. The amp used to light up
2 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: MY AMP TURNS ON BUT NO AUDIO OUTPUT TO MY SUBS! I
First, test your sub terminals for an Open connection, or no resistance. This is to test if your sub is blown. This is usually the case.
Double check your wiring, not only to the sub, but from your headunit to your sub. Make sure your headunit is configured to work with your amp, if you have a setting for this (for instance, SUB: ON).
Posted on Jul 14, 2010
Where can I find a manual for p9715b
http://www.retrevo.com/s/Planet-Audio-P9717B-Car-Videos-review-manual/id/23652ci668/t/1-2/
Mar 30, 2015 | Planet Audio P9717B / P9712 Car Video...
My planet audio px4000d amp powers on but green or red light dont come on
disassemble check internal fuse or for burned track also recheck the antenna connection -the thing that powers the amp on.Use a multimeter to test different points to ground potential. the one that doesnt have it has the problem.
Jun 22, 2014 | Planet Audio PX4000D Class D Monoblock...
I have a planet audio rdx 1000. I don't use it
I think maybe you pushed the subs too hard and the amp shut down in a way that will require repair
Apr 08, 2013 | Car Audio & Video
Why this planet audio protection light always comes on when i turn up the car audio
The amp in question is a very entry level amp. Meaning it needs to be ran at moderate ohm load. And have plenty of power to feed it. Check your grounds. Pos. Etc.
Feb 03, 2013 | Planet Audio AC1500.1M ANARCHY CLASS AB...
Protection light is on all connections are ok
If the protection lights are on it you will need to check the owners manual to figure out why it is in protection mode. The most likely reason is that the power wires are not properly connected. This could be the ground wire not being solidly connected to the vehicle chassis in a paint-free location or it could be the live power wire. Check your connections and connect them all properly. That should fix the problem.
Mar 05, 2011 | Planet Audio VX602 Car Audio Amplifier
Turns on but dosn't show any video sounds like it wants to start but only the blue power light stay on got sound but screen stays black
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 08, 2010 | HP Pavilion dv6000t Notebook
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
PIONEER DEH-P86DHR NO SOUND!!
With these units, the internal amplifier is an IC that fails sometimes. It can leave the rest of the unit working ok, bit will have no audio. There may be audio from the line level RCA's but not from the speaker outs. Smell the back of the unit to see if it smells burnt. Most of the time it will, but not always. The IC is usually something like a PAL007a or similar. If you are good at soldering, you can order the part, and change it yourself. If not, you will need to seek a technician to replace the part. You may also try an external amplifier and RCA's instead of fixing the IC.
Jun 15, 2009 | Pioneer DEH-P86DHR
Problem when hooking two 12 inch subs to one amp
the amp is no where near strong enough that sound you hear is called hard clipping and it will destroy your subs in minutes. depending on what model JL subs you have I can sell you a better amp.
Dec 30, 2008 | Planet Audio VX602 Car Audio Amplifier
Planet Audio VX602 Car Audio Amplifier Logo
165 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
