Question about Samsung Televison & Video
Use of Video/DVD player whist Set-top box plugged into SCART
When Set-top box is plugged into SCART, all 99 channels show Set-top selection. Video tuned into channel 6, only available when I physically remove SCART from TV.
Is this normal?
How do I use both without unplugging one?
  • aidanjthomas Feb 12, 2009
    i have no tv manual, hence the question.
  • Anonymous Mar 18, 2014
    How do I delete channels from a Topfield TBF-7110 Set Top Box
  • 79 Answers
Manuals
Posted on Feb 12, 2009
I have lost the av channel and cant get it back
Not sure why you would need the AV channel. As long as the tv is switched on before the set-top box it should automatically show the video content as soon as the scart receives input.
I have not used the AV channel on any of my tv's since the digital switchover.
I am still using vhs tapes, a dvd player and a dvr top-box and use a multiway scart switch to select which to input to the tv scart.
Feb 20, 2015 | Televison & Video
My VCR/DVD, freeview box and non digital tv will show prerecorded video and DVD but will not record (or if it has it will not display). Could it be that the set up is not wired up correctly? The freeview...
Unless the Freeview box has two tuners then your going to have problems anyway when you want to record something and watch the non-digital TV at the same time. The solution is simple get another Freeview box (they are around £10 at the moment on E-Buyer.Com) get a box like this:
grubhead_17.jpg Available on Amazon (Scart switching box). This plugs into the TV or you can connect via one of the freeview boxes. Whatever works best.
The VCR has the other Freeview box connected to the second scart. (select AV2 when setting the channel to record and set the box to the channel you want to record) the first scart from the VCR plugs into the above box. When you want to watch press the switch.
By the way if the VCR has PDC on it set it to off, as it no longer works with digital.
Aug 21, 2011 | Televison & Video
Dont know how to connect dvd player and digital set top box to the same tv. set top working,dvd player not showing visuals on tv
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 03, 2010 | Televison & Video
How to get all freeview channels-all i get is the first 5 channels
Go to menu, find "autoprogram" setting and select it. It will scan all available channels
Aug 17, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
2 AV inputs, only 1 works at a time.
hello try using a scart block at the rear good luck
Jul 19, 2009 | Sanyo Televison & Video
No colour when digital set top box attached
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Jun 10, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Recording digital channels
Connect your set top box to Scart L2 (the Right hand one).
Select Prog 1. Then Channel down until you get to L2.
This should work.
Jul 12, 2008 | JVC DRM10 DVD Recorder
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Open Questions:
Televison & Video Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
