Question about Rode (VIDEOMIC) Professional Microphone
Rode NT2 got Phantom!
I am borrowing an NT2 model number B35521 and using it with an Mbox mini interface. The button on the back for Pad is the same as the button for 48v Phantom but on opposite sides of the xlr input. I pressed it and heard crackle then quickly switched it off. Checked Cable and another mic and Mbox is still functioning in channel. Did I fry this mic? Solutions? Repair? Please help. Thanks, AM
Well... Rode NT2's are condenser mic's that require phantom power to work. So the phantom switch should be on. When you turn phantom power on you usually hear a bump sound (through the amplifier). In this case, nothing is broken.
Your picture is of a Rode Videomic (not an NT2) which is a stereo mic for video cameras. If you had some kind of stereo mini to (single) XLR adaptor, and put phantom power through it, the mic would probably be damaged. But maybe not... just try again without phantom power to see. a stereo mic won't work very well with the Mbox Mini because it only has one mic preamp.
Posted on Feb 15, 2009
How do you set pattern on Rode NT2? Does the mic function the same on battery power as phantom?
The cardiod pattern is as the instruction manual dictates and there is no difference between 9v battery or 24/48v phantom power.
Mar 20, 2014 | Rode Audio Players & Recorders
Can I connect the Rode NT2 to sound mixer
Yes. You'll need to engage phantom power for it to function.
Dec 29, 2011 | Rode NT2 Professional Microphone
Hello There, I just bought the Rode NT1-A, and I am trying to record in protools, but i'm not getting any levels whatsoever. I'm plugged in to an MBOX, in the XLR, I have Phantom Power turned on,...
It sounds like you have done everything right. It would be a good idea to check both the mic and Protools system separately. If you can, verify that the mic works using another device such as a mixer. Also try getting a level into Protools using another mic, preferably a dynamic which doesn't require phantom power. If you are trying to use an original MBOX under Windows 7 or the latest version of OSX then it may not work at all.
Sep 19, 2011 | Rode NT1A Professional Microphone
When i plug in my mbox mini 3 the blue light come on, but when i try to lauch pro tools it says that hardware is not recognize. When look at the mbox mini control panel, it says that it is not connected...
Assuming you are on a Windows system, go to Control panel/Sounds and devices/ and check that the Mbox2 appears as the default in the Audio and also Voice tabs/panes while unit is connected. If it is not, select it in each... if it is not in the list offered, then the drivers have not been installed for the Mbox.
Aug 24, 2011 | Digidesign Mbox 2 Mini Workstation
Rode NT1A: i got an adapter so i can input it in the mic input the pc says an audio device has been put in but i cant find it anywhere! please help me i also have an Acer Z5710
The reason it is not being picked up by your PC is because the NT1A is a condenser microphone and it requires an audio interface that can supply phantom power (48V) to get it powered up. Without phantom power, the NT1A won't work. You many need to buy an external audio interface that provides phantom power to use the mic. Hope that helps.
Mar 03, 2011 | Rode NT1A Professional Microphone
Hi The pop shield has come off on my nt2.Where
You can have a new one not necessarily Rode. I think its better to replace since you can have it for $15 that can be mounted directly to your mic stand. Hope it helps
Mar 16, 2010 | Rode NT2 Professional Microphone
Rode NT2-A
No. This is an analog microphone that requires no drivers. Check that another microphone works into the same input (and check that the phantom power supplied at the input meets the NT-2A specs).
Nov 09, 2008 | Rode (VIDEOMIC) Professional Microphone
No gain
happened to me too, I just fiddled with the phantom power button (wiggled it a little while it was pressed in) and my gain came back *shrug*
Feb 21, 2008 | Lexicon Lambda Usb Desktop Recording...
PROBLEM KEEPIN MBOX 2 CONNECTION TO MAC LAPTOP
I have the same problem. Usually it will work when I reboot the computer. The trick is once you get the mbox working with the phantom power on, is to not turn off the phantom power during your session; the duration in which you use the mbox at that given time before shutting it down. You can switch the phantom off and it won't shut off, but if you press it back on, it may and for me more than half of the time it does shut off. I have a new problem with my mbox. I can't hear play back, even though I can hear sound from either input. Any suggestions?
Oct 26, 2007 | Digidesign Mbox 2 Barebone
Rode (VIDEOMIC) Professional Microphone Logo
658 people viewed this question
Top Rode Audio Players & Recorders Experts
Michial Gueffroy
Don Hart
Tom Chichester
Are you a Rode Audio Player and Recorder Expert? Answer questions, earn points and help others
