Question about Sony VAIO PCV-W600G PC Desktop
Specific key contact failure
My shift key does not work. Evidently there is lack of electrical contact below the key when I hit it. Is it possible to remove a particular key and attend to such contact failue, either with screwdriver technology or purchase of a replacement contact pad (the stuff just below the key which is pushed down when u hit the key)?
  • 2 more comments
  • kgopalrao Feb 12, 2009
    Is it a micro switch that operates the required contact? could mine be an older design, for I removed the key (the plastic cover with the relevant letter or description that one hits), and found a softish, round, seemingly spring loaded contactor below that gets depresed by hitting the key. This contactor is evidently not making the required contact on whatever is below it (a PCB?). I know I could just chuck it and buy a new keyboard, but it struck me as wasteful in many ways to just throw it away for one single malfunctioning key! Any further ideas?
  • kgopalrao Feb 13, 2009
    Dear Tampa Native,
    Thanks for the info, but isn't there a slight contradiction here. If the micro switch is a spring loaded contactor, how can it be soldered to the circuit board beneath it? Once soldered, to anything, it cant very well move when depressed by a finger hitting the key, and return to original position thro' the spring! Or can it? Would really appreciate an explanation. Thanks.
    K.G. Rao
  • kgopalrao Feb 15, 2009
    Dear Tampa Native,
    Thanks. I get the picture now, and also realise it's not worth my while to try and repair, even if i could do it which i doubt, for my soldering skills are very limited.
    In any case, what do u know, i seem to be way out of touch with keyboard prices. Of course, the last time I looked was several years ago, when i got my current keyboard on which one shift key is kaput, and the cost then was Rupees 1000 (I live in India), i.e. about $25 then. Today, on checking, I find i can get a new one for Rs. 200 at the low end (about $4). Quite affordable, compared to then. How much is it at the low end in the US?
    Thanks once again for the helpful dialogue.
    K.G. Rao
  • kgopalrao Feb 16, 2009
    Dear TampaNative,
    $5? That makes it about the same as here, except that in PPP terms our Rs.200/- is much more expensive.
    Thanks for all the info. It's been a real help in clarifying my ideas. You sound as tho' you're regularly into helping dummies like me. Keep it up. Cheers.
    K.G. Rao
    President:
  • 778 Answers
Desktop keyboards are generally less expensive to replace than repair. But, if you must you should determine if the micro switch below the key is worn out, stuck, or dirty. If stuck or dirty some nonresidual contact cleaner may fix it up. If the switch is bad, some better than average soldering skills will be necessary along with a compatible micro switch.
Posted on Feb 12, 2009
  • 1 more comment
  • Frank  Fernandez
    Frank Fernandez Feb 12, 2009
    That round spring loaded contactor is the micro switch and it should be soldered to the circuit board beneath it. No further ideas just the ones posted earlier.
  • Frank  Fernandez
    Frank Fernandez Feb 14, 2009
    Not at all. The spring loaded switch is in a housing that has leads/legs/contacts protruding from the housing which make solder contacts to be soldered to the board.
  • Frank  Fernandez
    Frank Fernandez Feb 15, 2009
    I can find decent keyboards from around $5.00 US and up, so it's really not worth the trouble to repair them unless you have the soldering skills and parts laying around.
I have a code PO651 on a 2005 Chevy Alvalanche
Symptoms of a P0651 code may include: Failure of the transmission to shift between sport and economy modes Transmission shifting malfunctions Delayed (or no) transmission engagement Failure of the transmission to switch between all-wheel and two-wheel drive modes Failure of the transfer case to shift from low to high gear Lack of front differential engagement Lack of front hub engagement Erratic or inoperative speedometer/odometer
Read more at: https://www.obd-codes.com/p0651
Copyright OBD-Codes.com
Sep 12, 2017 | Cars & Trucks
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
Transmission shifting mechanism
Hi, Kevin for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. If necessary, transport your bike to the dealer or shop and have a professional technician take it for a test drive, if it is in running condition, and give you a written estimate of repairs and answer any specific questions you may have about your problem. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.carlsalter.com/diamo-service-manuals.asp
Scooter Parts for Chinese Scooters Atvs
Chinese ATV Owners Repair Manuals
Diamo Cruiser Twin 250 2006
Tips Tricks
Jul 20, 2014 | 2006 Diamo Cruiser VTwin 250
Shift Key Problem , Royal Quiet Deluxe
There is a carriage shifting screw on both sides of the typewriter. You will recognize this because it is a screw that has a big bump head with felt on it. It is being hit when you hit that shift lever. You will have to loosen the securing nut first before adjusting.
Nov 17, 2013 | Royal Office Equipment & Supplies
Start problem?
Let me briefly explain what happens when you turn n the key. All power is off in the off position with the possible exception of the brake light. When you turn on the key, you supply power from the battery to the electrical system. Typically, all systems are powered through a connection on the start solenoid. When key is on and the solenoid is in the off (or rest) position - all electrical works. When you energize the start solenoid, you need all the power you can get to run the starter - everything electrical turns off. After the start, you release the start button, everything electrical comes back on (solenoid returns to the rest position).
In your case, you say everything goes dead when you press the start button - this is as it should be - however, the mechanics of this system should deliver power to the starter - which evidently it is not. (A solenoid is nothing more than a electric powered heavy duty switch) It is possible your solenoid is worn out. There is heavy sparking/burning of the contacts every time you press the button. First thing to do is check voltage on the start side of the solenoid when you press the button. Voltage should be the same as on the hot side with the key on. Other possibilities - the wire from the solenoid is loose, damaged or disconnected, check both ends for tightness and cleanliness. There is that possibility there is a problem with your starter. Removal is not for the faint of heart though it is possible. There is also that possibility your engine is locked up and your starter can not turn it over because of that. If this is the case and you have a amp meter - you will see heavy draw on the starter wire. If you have a volt/ohm meter, you can so all the prelim checking.
I hope this helps you with your trouble. Good luck and thanks for using FixYa.com
Jul 29, 2013 | 1995 Suzuki VS 1400 Intruder
I want to calculate powers on my calculator but am unsure what buttons to press
You have two buttons to calculate powers: The [x^2] calculates the square of a number while the [caret ^] key allows you to calculate any power, be it with integer, fraction or negative exponent.
Both keys are next to one another, one below OPTN and the other below the VARS key.
To calculate roots, you have the square root [SHIFT][x^2] the xroot key [SHIFT] [caret ^] , the CUBE root [SHIFT] [(] , and the inverse key [SHIFT][).
Feb 28, 2011 | Casio FX9750GII Graphic Calculator
Both shift key wont work on my laptop
Remove the top pads of the keyboard and use a good cleaning brush with a vacuum cleaner to remove off all the dirt from within specially of dust accumulating . If there is no response check the link from the keypad to the motherboard, remove and reset the connection.
If not the fault can be failure in the contact pads below the keys.
Open control panel and click on keyboards, change the settings for user with more sensitivity and save. If this wont work the keyboard panel must be checked again.
Nov 25, 2010 | Computers & Internet
I have a acer 6530 laptop. In order to use the
The delete problem you described sounds application specific. For example in Windows Explorer, if you just click on the Delete key, you will only send the deleted object into the Recycle Bin where it can be restored if required. If you want to really delete an item, you click on Shift-Delete key.
Therefore, to answer your question, yes it should be possible to hit just the Delete key but for certain applications like Windows explorer, you will not really be deleting the item you selected.
Jan 11, 2010 | Acer NSK8458AN Keyboard
My Dell laptop performs control functions without pressing ctrl
First thing to always do is kick it. Now that that didn't work, it just seems like the key is sticking. Look under the key to see if there is any junk underneath or possibly press the key several timers then hold it in. If it is still sticking it could be a problem with the insulatinh membrane between the contacts. if you remove the ket and peel back the membrane just enough to get to the contacts, you can lay a very skinny piece of electrical tape between the contacts. probably 3 contacts on top and 3 on bottom, lay the tape horizzontally between the top 3 and bottom 3. Hope you can get it, good luck
Seth
Jun 12, 2009 | Dell 0Y3740 Keyboard
Shift key does not work
The chances are that you need a replacement keyboard it is probably coming apart. Contact Geo. Beyers Co. @ 1800-392-8085
DickyO
Jun 11, 2009 | IBM Wheelwriter 30 Typewriter
Sony VAIO PCV-W600G PC Desktop Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
