Question about Nokia 6630 Cellular Phone
Bluetooth problem how i use my bluetooth connection,,?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
It totally depend on how ur using the blue ttoth.. if u want to use it for sending files just switch on ur bluetooth n then goto ur filemanager or gallery select the fle u want to send ,then take options n select send using bluetooth. or if u want to receive files just enable bluetooth n then in the same window u enabled bluetooth conn there is an option for hiding the bluetooth. so unhide it. then ask the person to send the file .now u ll be prompted for savein the file.so accept it.. n the file wil be in ur inbox if ur using 6630. N btw be more specific about wht you want....thank you.
Posted on Feb 12, 2009
How to on or off bluetooth on w508i. even how to change setting of bluetooth
Hi, To set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you
select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed
My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running
on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery
application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon,
the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already
exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the
devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new
search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to
be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and
the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a
passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device
to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the
device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via
Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the
devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for
both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is
shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the
message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
Hope it helps .
Fill free to pass your comment.
Thanks for using fixya...
Jan 08, 2011 | Sony Ericsson W508i Cell Phone
Tip
How to connect Bluetooth GPS using mobile phone
<p>Once I explain how Bluetooth GPS receiver to connect from a mobile phone. Bluetooth GPS Receiver is a device that continuously transmits its position (longitude, latitude and speed) using the Bluetooth protocol. If your phone is Bluetooth-enabled phone, you can connect to a Bluetooth GPS receiver to determine its position. To locate, connect to Bluetooth GPS and mobile phone to get the NMEA sentences for location tracking, you can also program a Java (J2ME) for your phone. Your program should do the following tasks: <br /> <p><br /> <p>1. Bluetooth device within the search area. Each time a Bluetooth device is discovered, discovery listener device Discovered trigger procedure. In the search is completed, the trigger listener discovery process inquiry Completed. <br /> <p><br /> <p>2. Get the name Bluetooth. We have a choice to a group list of Bluetooth-friendly name of the devices found to store. We also need a vector to devices found to store. <br /> <p><br /> <p>3. Select Bluetooth GPS receiver from the list of found devices. <br /> <p>4. Find service by the GPS device. Bluetooth GPS Receiver provides an L2CAP service so that the program needs to find this service for GPS url connection string for. <br /> <p><br /> <p>5. Get connection string from the GPS device. Connection string to the URL will have this format Url = "btspp: Address / bluetooth /:" + + L2CAP_UUID "permission = false; encrypt = false"; <br /> <p><br /> <p>6. Sign up and receive sentences from the GPS device. After plugging in the url in step 5, you can open the connection and extract sentences from the connection string. <br />
on Jun 26, 2011 | Cell Phones
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Its saying pin blocked
hi friends.if you have samsung c3200 mobile.and you want to connect your mobile with your computer.for useing internet connection.you do not use data cable.you just buy one bluetooth card nerat computer shop.RS-140 price bluetooth card.now you install bluetooth software and on both bluetooth pc\mobile.now you create dail-up connection.you can use internet by bluetooth connection mobile and pc bluetooth card.now if you help then contact with your mobile service provider.for settings.ok but do not buy cheep kind of bluetooth card you buy (ENTER)BLUETOOTH CARD.also if you have airtel service provider then setting i tell you now.apn-*99# and airtelgprs.com
Nov 26, 2010 | Cell Phones
I WANT TO CONNECT N 72 TO MY PC
N72 can be connected to your PC in two ways.
1. By USB cable
2.Via Bluetooth.
Bluetooth means you need to buy a device called Bluetooth dongle to provide bluetooth connectivity to your system.
For both usb and bluetooth, you need a software called Nokia PC Suite to access the mobile contents and for data transfer
Aug 03, 2010 | Nokia N72 Cellular Phone
Can't turn bluetooth on. If I restart the phone and then turn on bluetooth, I get a message "Switching On Bluetooth" but it doesn't turn on. After that, nothing happens when I select "on", not even the...
Set up a Bluetooth connection
Select Menu > Settings > Connectivity > Bluetooth and take the following steps:
1. Select My phone's name and enter a name for your phone.
2. To activate Bluetooth connectivity select Bluetooth > On. indicates that
thanks
May 16, 2010 | Nokia 6301 Cellular Phone
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Nokia 6630 Cellular Phone Logo
48 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
