Question about HP Pavilion dv2000t Notebook
Press f4 to resume
Whenever i start my system ,i heared a single beep sound
and then a screen is appeared having hardware configuration details and at bottem it shows
press to resume
whts problem with my system and how it configured
  • Anonymous Feb 13, 2009
    my mainboard is intel D865GVHZ with LAN
    and in its bios setup their is no such "stop booting on error" option i find
    do u have any other advice or solution
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
U need to go into bios setup.this can be done by pressing del button on ur keybadr while booting is goin on. some time the key to be pressed will be F10 or F1 instead of del key.
There will be an option as stop booting on error. disabl;e that..n it ll be fine.. btw to find out the error u'l have to specyfy each n every settings in ur bios.So its better u to ask for a person who knows these things to ur home.. Else u can do by exploruing these things urself.It ll be fun..i would prefer this..
Posted on Feb 12, 2009
  • vasusachin24 Dec 10, 2010
    and how to find out what error stopped it from booting?
My pc laptop does not start due to error 2000-03000
Try using the Last Known Good Configuration:
  • Remove any CD or DVD from your computer, power down, then power up.
  • Do one of the following:
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you'll need to try again by shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start, and then press F8.
  • On the Advanced Boot Options screen, use the arrow keys to highlight Last Known Good Configuration (advanced), and then press Enter.
  • If your computer has more than one operating system installed, use the arrow keys to highlight the operating system that you want to start by using Last Known Good Configuration, and then press Enter. Windows will then resume starting normally
  • Nov 13, 2013 | Dell Computers & Internet
    Echo through speakers
    Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
    Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
    This can be accomplished by accessing the Sounds menu in your operating system.
    Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
    Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
    Listen to hear if the echoing problem occurs.
    If it does, you need to configure your speakers or check to see if it is a third-party issue.
    Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
    Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
    Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
    However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
    Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
    Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
    Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
    hope this helps
    Sep 15, 2012 | ASUS Computers & Internet
    Power on battery fully charged computer not booting up
    Use the Last Good known Configuration::
    To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
    Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your Windows on the first attempt, the backup copy is also corrupt.Use system utility software like RegInOut after restarting windows.
    Apr 13, 2012 | Packard Bell EasyNote E2 316 Notebook
    My laptop screen is black but it turns on
    Why Windows Vista Boots to Black Screen?
    • The MBR file is corrupt
    • Partition table is corrupted
    • NTLDR is corrupted
    • Registry is corrupted
    • Boot sector of Windows is damaged
    Follow the tips below to fix the problem:
    • Scan PC for Viruses
    • Clean Registry
    • Run Last Known Good Configuration
    • Repair Windows
    revive your WindowsXP on the first attempt, the backup copy is also corrupt.
    Jan 03, 2012 | Compaq Presario CQ56-115DX Laptop
    Pc wont boot up
    Restore to last known Good Configuration:
    Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
    Jan 01, 2012 | Computers & Internet
    Black screen on aspire one
    Restore to Last Known Good Configuration:
    Dec 17, 2011 | Acer Aspire One Netbook 8.9" Notebook
    I have hP mini 1000 that won't boot up windows. Just shows me Hal.dll error message. How do I fix that if it won't start.
    you will need a copy of windows and an external disk drive then have it boot from the cd when it boots select install windows then leave the current drive intact with no changes or if the repair option comes up you can select that. do not select the repair at the first menu unless you are an expert in dos, always go to the install.
    Jun 30, 2011 | HP Mini 1000 Netbook
    I'm having problem with my Compaq Presario CQ60430SA Notebook PC there's a beeping sound during start up every time i open my laptop about 30 - 40 beeps before it begins to load the operating system.
    Beep sound indicates some hardware parts are not functioning properly(test all parts like Bluetooth,touch pad,Keyboard(test all the keys)etc...... If all parts are functioning properly reinstall the operating system
    To reinstall you need *A copy of operating system loaded in a DVD or a CD
    To reinstall *Insert the os CD to DVD drive *When your PC's logo appears keep pressing F12 *Select boot from DVD/RW++ *Select "INSTALL NOW"(in windows operating system) *Select a drive in which the operating system is to linstall *Follow the Instructions....
    Thank you Don't forget to rate
    Jan 28, 2011 | Computers & Internet
    Will not re-boot
    Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
    To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
    • Boot.ini
    • NTLDR
    • Ntdetect.com
    After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
    #2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
    Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
    #3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
    To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
    Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
    #4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
    To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
    Please let me know if you have any further questions or concerns.
    Thanks.
    Apr 30, 2010 | HP Pavilion dv1000 Notebook
    Which function key allows to switch to tv
    You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
    If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
    If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
    Here are these details in other way :
    First time pressing FN + F4    ---> Display on LCD and External display
    Second time pressing FN + F4 ---> Display not on LCD but on the External Display
    Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
    Below are the details of what the Function keys in your DV1000 Notebook work :
    fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
    Hope this helps...
    Oct 11, 2008 | HP Pavilion dv1000 Notebook
    HP Pavilion dv2000t Notebook Logo
    1,130 people viewed this question
    Top HP Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
