Question about LG Dishwashers
DE code flashing on my Lg dishwasher (model 2131).
Water is standing in the bottom of machine.
  • Anonymous May 16, 2009
    how do I check to see if the waste pump is blocked?
  • 32 Answers
Hi, it seems you have a drainage problem. Try to reset the machine, or start a new cycle. It should start draining straight away. If not, listen carefully to see if the dishwasher is making a huming noise. If it is then the waste pump is blocked. If not it might need a replacement pump.
Posted on Feb 12, 2009
Displays E1 code. water is on
Hi there Dolly, error code E1 relates to water leaking. Its the code the machine displays when the flood switch in the bottom of the machine activates. The flood switch activates when the bottom of the machine gets filled with water from a leak. I surgest you have a look underneth the machine for signs of water. I hope this helps regards Gary.
May 04, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
The power is on the cycle light is on but on the right the first two lights are flashing together. help zanussi aqua pulse de 6744 s
Hi, the first thing the dishwasher does is fill with water, so this sounds like a Anti Flood water pump problem this is just behind the water pipe that feeds the clean water into your machine, one thing to check is if the machine is empty of water at the moment, if the machine has water in the bottom then it could be the Drain Pump.
Jul 29, 2010 | Zanussi 24 in. DE6744S Free-standing...
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
Hi, I need a manual for LG LD2131 SH
Thanks for using FixYa. You can download the user manual for your dishwasher from this link--
LG LD 2131 SH Dishwasher User Manual
Please revert for further assistance.
Jul 21, 2009 | LG Dishwashers
De error code
"dE" means that the door hasn't been closed properly. Check the inner seals of the washing machine particuarly at the bottom where water can get clogged. Also check the rubber seal around the front door to see if it has popped out or out of alignment. Also, "DE" in full letters can mean that the drain needs to be cleaned. Switch off the washing machine, pull out the flap on the bottom LH front of the machine, find the water tube and drain the water out of the LG. Then unlock and inspect the actual plastic tray/grid when twisted to unlock and pull out. There should also be a "drain" function on the main dial as a general maintenance option. Make sure you do this to keep your machine going.
Dont forget to rate this please if this solution works. Many thanks.
Mar 28, 2009 | LG WM1812C Front Load Washer
Dishwasher won't run. Light flashing on Air-Dry button.
check bottom of dishwasher, front left, round breather, gets clogged...clean and restart
Mar 13, 2009 | Dishwashers
"E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
May 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LE stands for "Locked Motor". It means the main pump motor is bad.
Dec 07, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
LG Dishwasher
according to the manual that i have just downloaded from the net,E1 code means.water leakage in Hose connections.
.water is leaked by damages
hope this helps,
Sep 20, 2007 | Dishwashers
"E 1 code error
The fault is that the anti flood device is activating, you have a leak somewhere in the base of machine. Regards Engineer
Aug 05, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
281 people viewed this question
Top LG Dishwashers Experts
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
