Back to:
Tags:
D-Link DUB A2  Serial Adapter
A7M-266 / WinXPsr1 and usb2 problem
By Gary10 - usenet poster
I have the a7m-266 and added in a pci card for usb2. The card is seen by
the OS but I can't get it to recognize usb 2. It runs at about 1MBs for
transfers from a Maxtor 1touch.
Help
TIA
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
FixYa! (100)
kioner
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Well glad i could help. take care.
ASUS P4T533 / P4 2.8 @ 3.0 GHz
ASUS Ti 4600 / 1 Gig 1066MHz
RAMBUS / Audigy 2 / XP Home
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on A7M-266 / WinXPsr1 and usb2 problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Pasty
Rating: 0%, 0 votes
Good News. I removed the modem in slot 4 (it wasn't setup yet and showed a
question mark in device manager). Moved the USB 2 card to that slot and
everything is running OK now with the drivers from XP Service Pack 1.
Thanks a LOT for your help.
Robb
Thank You!
Solution #3
Not Rated (0)
Riddle
Rating: 0%, 0 votes
Good idea... I'll shuffle things around a bit and let you know what happens.
Thank You!
Solution #4
Not Rated (0)
Phoebe
Rating: 0%, 0 votes
Perhaps move it to a diff slot. Mine is 2 down from AGP slot
Thank You!
Solution #5
Not Rated (0)
Riddle
Rating: 0%, 0 votes
Thanks for getting back to me so fast.
What I see is - According to ms this is the correct listing for USB 2. However, when I plug
my Maxtor in is shows up as high speed device plugged into non high speed
hub. The error balloon leads to a dbx that shows a high speed controller
with all ports empty. I try plugging into different outlets on the card
with the same results.
2 days ago (before I formatted and reinstalled XP) the drive showed up as
USB 2 for no apparent reason. Now I remove all traces of USB from device
manager and reboot and it still won't show.
Robb
Thank You!
Solution #6
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
I recently installed a D-Link DUB-A2 USB 2.0 PCI adapter in one of my
A7M266 running Win XP Home systems and it works fine.
In device manager do you see a line in Universal serial bus
controllers that says VIA USB enhanced host controller? That would
indicate its properly installed and recognized
Thank You!
Can you Help with these Serial Adapters problems?
Serial Adapters
require driver for usb c2110 modem trrfyghg
Serial Adapters
My DYNEX does you disconnect the cable of the badge for...
Serial Adapters
but i know catv is coming into the outlet because i am on...
Serial Adapters
I am in southern Alabama and have not been able to find a...
Serial Adapters
I have adopter but now I have windows vista no longer xp
Loading problems.
Repair Service
Find Serial Adapter Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Networking Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
