Question about Dell Inspiron 9100 Notebook
Vertical black bars screen
When I started my computer, vertical black bars went from the top of my screen to the bottom across the whole screen. It looked like a jail cell. I restarted and the problem went away. This is the first time this has happened, but sometimes when I start my computer, the screen does not even turn on.
  • Dell Master
  • 998 Answers
Try connecting an external monitor to the 15 VGA (video) plug on the laptop and see if it displays properly on the monitor. You may have to direct the video from the laptop to the monitor by holding down the blue <FN> (key next to the space bar) and then press down the <F8> key.
If the display on the external monitor is correct, then you either have a problem with the laptop's LED display screen or cable that connects the LED to system board. Here is a link for the service manual:
ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-9300_service%20manual_en-us.pdf
Posted on Feb 17, 2013
5 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Vertical Lines on Dell Insprion 6400
It may be due to bad LCD screen, LCD cable or Video board. If you dare, open the monitor and tighten the cable connections Go to www..chub.com .for details of How To.
Posted on Dec 20, 2007
snowman533
  • 33 Answers
SOURCE: Vertical black bar across the screen
sounds like the screen settings are out, try changing the screen settings, not sure which button it is though i rarely play around with laptops
Posted on May 19, 2009
  • 1082 Answers
SOURCE: so i open my laptop.
This could be caused by a couple of problems but you are going to need access to a second computer to determine the problem.
1) You have a disk that is failing and it has had an error. Got to the disk makers site and down load their diagnostic program and check the disk. This is a stand alone CD so you don't need to boot into the OS.
Another program that can temporarily fix errors is http://www.dposoft.net/ This program will stop after fixing the first error unless you buy it. Again, this is a stand alone.
If it is a disk error, you need to quickly get your data off and install a new disk.
Don't have a second computer? then you need to take it to a local computer store where they can remove the disk, install it in a desktop and check it for errors.
2) This could be a virus, but I think #1 is your problem. TrendMicro.com has a free online virus scan if you can install the disk in a second computer.
Posted on Aug 11, 2010
  • 998 Answers
SOURCE: screen particially blacking out with vertical
Tryconnecting an external monitor to the laptop. You may have to select the videooutput to display on the external monitor by holding down the blue key and pressing the blue CRT/LCD (located on one of the keys, likeF8,F9, etc..). If the problem occurs on the external monitor with the batteryor AC power, then you have a problem with either the video card or motherboardin the laptop. If the problem does not happen using the external monitor thenyou laptop's LCD display is going bad.
Posted on Aug 01, 2011
Vizio vertical line
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Apr 03, 2017 | Televison & Video
Intermittent black or snowy horizontal bar across the top
You're somewhat sound in electronics I assumes. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | JVC PD-42WV74 42 in. Plasma EDTV
My stating button is at the top of my screen how do i adjust
PUT YOUR CURSUR ON THE TOOL BAR THAT YOUR START BUTTON IS ON.
PRESS AND HOLD THE LEFT BUTTON ON YOUR MOUSE.
WHILE HOLDING THE BUTTON DOWN DRAG IT DOWN THE SCREEN TO THE BOTTOM.AS YOU DO THIS YOU SHOULD SEE THE WHOLE BAR MOVING DOWN, PERHAPS FIRST MOVING TO THE RIGHT OR LEFT VERTICALLY AND THEN ON DOWN TO THE BOTTOM OF YOUR SCREEN.
WHILE AT THE BOTTOM RELEASE THE LAFT BUTTON ON THE MOUSE, THE BAR AND START BUTTON SHOULD NOW REMAIN IN THE LOWER SECTION OF YOUR SCREEN..
Jun 23, 2012 | Computers & Internet
May 19, 2009 | Dell Latitude D800 Notebook
Monitor aspect
I think you need to check all capacitor in vertical section. Maybe there is a leaky capacitor, and one the cause of black bar.
Jun 26, 2008 | Dell E173FP 17" LCD Monitor
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Dell Inspiron 9100 Notebook Logo
65 people viewed this question
Ekse
Clive
Clive
