Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
LG Tromm WM2277HW Water level to low
I belive the water level in my machine is too low. In all of the pictures it shows a water level that you can see throught the door but the water level in my washer is less than an inch during the washing cycle. Is this typical? If not, is there a way to adjust the amount of water in the machine during the washing and rinse cycle?
  • Anonymous Mar 22, 2014
    rinse cycle water level very low w
    ater dosent cover clothes, seems as though there not beinginsed properly
    r
  • 547 Answers
This is normal the pic are all photo shop water you clothes are clean right?
Posted on Feb 12, 2009
Lg tromm wm2277hw will not spin
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously to enter QC test mode and check the frequency of the water level, if the display shows 248 or more:
NO: Check the sensor switch assembly and also the pressure hose, replace either if faulty.
YES: Press the START/PAUSE button twice while in QC test mode and check whether the drum spins at low speed, this is normal.
If no reaction from the drum at all the the main PWB assembly board will need replacing.
Feb 09, 2014 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW
Does spin only work well?
Apr 11, 2017 | LG WM-2277HW Front Load Washer
Not completing cycle error IE
IE is a water supply error. turn water off to machine and unscrew your 2 water hoses on back of machine and clean inlet screens with old toothbrush. if they are clean, you probably have a stuck closed water solenoid.
Jul 25, 2010 | LG WM2277H Front Load Washer
Lg tromm wm2277hw rinse spin error OE
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Oct 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Spinning cycle
usey only takes about 2 tbs soap ather than that bad main board make sure you have cold water going in washer
Feb 24, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
560 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
