Question about Cannon Canon i960 Photo Printer
Thank you Dear Rockitman, thank you very much , your good man
    President:
  • 2,559 Answers
Your welcome,Glad I could help.
Please click the blue FIXYA link at the bottom.
Posted on Feb 12, 2009
Paper wrinkles up time it gets about an inch in the rollers out of the paper tray. I am in sumter s.c. and would like to know where i can get it repaired in this state? Thanks
Hello Hawk.
My name is Jeff and I work for a company named Advanced Office Systems which has been in business for over 30 years.We are based out of Knoxville Tennessee and unfortunately can't come to help.But I feel confident my service manager may be able to help you find a service provider in your area.He's a good man named Dan Llewellyn (pronounced "loo ellen").His number is 865.966.0770 ext 217. A busy man ,but a good man. I hope I have helped you so if you don't mind please acknowledge my help thru FIXYA. Thanx and I wish you the best.
Jan 14, 2011 | Canon MF6530 Black and White Copier
Belt change
Then I suggest you use a 1/2 inch breaker bar, and the appropriate socket to fit that bolt head, on the tensioner pulley bracket. You want to pull the tensioner pulley away from the serpentine belt, just long enough to slip part of the belt off of a pulley. Any pulley that is easiest to access, doesn't matter. Then slowly release the tensioner pulley, until it's at the rest position.
Before you begin, look at the radiator support, or on the fender well, or maybe up underneath the hood. Look for the diagram that shows the serpentine belt 'path'. If there isn't one present, and you don't have the Owners Manual, I would suggest at this time to make a drawing of the belt's path. Saves a lot of headaches later.
May 17, 2009 | 1999 Dodge Ram
Battery is good ..replaced started ..lights radio and everything else works ..but when I turn the key it gives 1 loud click and that is it..
Thank you Vortash..You are the man..You were right about the earth wire not grounded to the motor correctly...I took it off and cleaned it and put a new nut back on it and snugged it up ..and that baby fired right up..I will using your services the next time..I have a problem..5 Big Stars thanks man...Archermathews@aol.com
May 16, 2009 | 1998 Volkswagen Golf
Water escaping from radiator cap
If it is over flowing.(Over fill would leak into the overflow tank,Not out of the cap)
This can be due to:
  1. trapped air in the system.
  2. A leaky head gasket.
  3. a sticking thermostat.
  4. improper coolant/water mixture.
  5. non working fan.
  6. Faulty cap
May 05, 2009 | 1999 BMW 318 ti
Premium ge refrig
peyton you got it right on!!! i just sent an email to the expert section on fix-ya asking this very question.
i couldnt believe that this person said that he had the best response and i think your answer about the thermistors might be the right choice too.
if you look at these other guys profiles, they have car expertise and it looks like they just are jumping on the 6 bucks.
i have found several of these that had weak windings in the fan motor causing low air flow, but also have had a couple with open thermistor too.
you must actually do this for a living as not too many people no enough to give real answers.
by the way in an A&E tech with sears. but dont tell anyone!!!! LOL
take care too tom/ tzweeb
Feb 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Virus
Open task manager and Kill the following process sysdpt.exe
Open registry
Delete these entriesHKEY_CURRENT_USER\software\microsoft\windows\currentversion\run\sysdpt
HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run\sysdpt
Remove the following filesysdpt.exe in Windows\system32\
Please rate this solution
Jan 17, 2009 | Computers & Internet
C325 BEE
I didn't solve the problem myself, but I knew a man who knew a man at the BBC who could. The problem was caused by an overheating condenser. You'll need to find an electronics expert to identify what condenser.
I have had no problems since. Good luck!
Dec 12, 2008 | Audio Players & Recorders
Vertical problem
IT COULD BE ADJUSTED from the inside , if your handy and good W/ tools you could fix it , if not , call the service man , thanks AJ
May 19, 2008 | Sony KV-27S35 27" TV
Configure D-link DP-310P by using Unix
You need to use the LP service /etc/init.d/lpd in UNIX and you need to set up the printer definition. Use the man page "man lpd" and it will tell you how to configure it. The kind of driver you use will depend on the kind of printer. Eg., is it an HP Laserjet compatible or a Postscript compatible. That affects the kind of "language" lpd will use to talk to the printer. Setting up LPD can be fairly complex.
Another avenue is using CUPS which is a much better print server solution. You can read the man page by typing "man cups" or "man cupsd".
Good luck,
David
http://www.tekops.com
Mar 04, 2008 | D-Link Express EtherNetwork DP-301P+ Print...
Cannon Canon i960 Photo Printer Logo
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Victorman
Victorman
Greg Cann
Greg Cann
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
